If you're experiencing issues where your product translations remain in progress even after completion and the translated product has a different layout than the original, it might be due to a plugin conflict.
We recommend deactivating the CMS Masters Importer plugin to resolve these issues. This plugin, often used for importing demo content, can interfere with the translation process. If you need to use this plugin for importing content, you can activate it temporarily as needed. For further details, you can refer to a similar case discussed here.
Please note that this solution might be outdated or not applicable to your specific case. We highly recommend checking the related known issues, verifying the version of the permanent fix, and confirming that you have installed the latest versions of themes and plugins. If the problem persists, please open a new support ticket.
This topic contains 27 replies, has 2 voices.
Last updated by Paola Mendiburu 9 months, 1 week ago.
Assisted by: Paola Mendiburu.
July 28, 2025 at 11:58 am #17274810
iroM
I changed to the default theme and the whole site "broke". I mean the appearance and the layouts. Therefore, the products pages too were not correct.
I also brought back the yesterday's backup because when I switched back to the previous theme, the site remained "broke".
July 28, 2025 at 2:12 pm #17275674
Paola Mendiburu
WPML Supporter since 11/2020
Would you give me permission to download a copy of your site using Duplicator?
This will allow me to investigate the issue without affecting your site.
July 28, 2025 at 2:26 pm #17275766
iroM
Yes of course.
Thank you!
July 29, 2025 at 10:54 am #17278438
Paola Mendiburu
I can confirm that the issue appears to be related to the theme. When switching to a default theme, everything works as expected.
As a workaround, please go to the English version of the product, click on Edit Product, and then click Update without making any changes. After that, the product title should appear correctly.
July 29, 2025 at 11:12 am #17278485
iroM
Hello again,
When I go at the edit page of the translated product and click Update then this error appears (screenshot). This only happens on the translated product page, on the original language the update works fine.
July 29, 2025 at 2:27 pm #17279340
Paola Mendiburu
When I deactivate the plugins of CMSMasters it is working properly.
Could you also try on your end?
July 29, 2025 at 3:20 pm #17279650
iroM
These CMSMasters plugins are necessary for the theme to work properly. I mean we can't have them deactivated otherwise the layouts breaks.
Also when I deactivated them, then I went to the edit page of the translated product and Update, as you said, the title was indeed fixed, but the menu went down at the title (see screenshots).
July 30, 2025 at 9:39 am #17281329
iroM
Have you maybe found any solution concerning our issue?
July 30, 2025 at 10:16 am #17281422
Paola Mendiburu
Hi there!
The issue appears to be related to the CMS Masters Importer plugin.
When I deactivate this plugin, everything works correctly.
As shown in this ticket https://wpml.org/forums/topic/ive-got-3-translations-that-take-a-lot-of-time/ the problem seems to be the same.
This plugin is mainly used for importing demo content, so unless you specifically need to import demo data, I recommend keeping it deactivated. You can always activate it temporarily if you need to import content again.
July 30, 2025 at 11:04 am #17281652
iroM
Alright, I have this plugin deactivated and tried to translate a new product. Now the translation works fine but another issue remains I mentioned before.
Look at this product for example
and the translated:
On the translated product page the menu re positions inside the title section.
July 30, 2025 at 2:36 pm #17282592
Paola Mendiburu
Could you please let me know from where are the settings for the menu position?
Before, I see it properly.
July 30, 2025 at 3:05 pm #17282803
iroM
I think there is no specific setting for the menu position. I mean it's already the default position we have not made any custom change.
Don't know if this theme settings page would help you
or maybe it has to do with wpml menu sync here?
July 31, 2025 at 1:40 pm #17285237
Paola Mendiburu
This is because you need to remove margin-right of the logo on this css:
.header_mid .logo_wrap {
    height: 100%;
    margin-right: 60px;
    position: relative;
    float: left;
if you change it to 20px you will see it correctly
    height: 100%;
    margin-right: 20px;
    position: relative;
    float: left;
But this is a problem not related to WPML, it is related to your css.
Also you need to translate the menu:
https://wpml.org/documentation/getting-started-guide/translating-menus/
