| - | 10:00 – 17:00 | 10:00 – 17:00 | 10:00 – 17:00 | 10:00 – 17:00 | 10:00 – 17:00 | - |
| - | 18:00 – 19:00 | 18:00 – 19:00 | 18:00 – 19:00 | 18:00 – 19:00 | 18:00 – 19:00 | - |
Last updated by Shekhar Bhandari 7 months ago.
| Author | Posts |
| April 14, 2025 at 9:14 pm #16931270 | |
svenH-12 |
| April 15, 2025 at 4:14 pm #16935414 | |
svenH-12 |
Subject: German Homepage Translation Not Showing Despite ATE Showing Completed Hi there, We would really appreciate your urgent help — we’ve been working on this issue for nearly 18 hours now and have gone through all possible troubleshooting steps, yet the problem persists. We are having a critical issue with the German translation of our homepage on hidden link. ⸻ 🔄 Summary of What We’ve Done: ⸻ ✅ What Now Works: ⸻ ❌ But the Issue: Please advise how we can fully reset the German translation memory for this page or manually force the translated content from ATE into the post. The issue is affecting our main homepage, and we’re unable to go live with German due to this. We’re happy to provide any logs, debug info, or backend access if needed. Thank you in advance for your support. |
| April 15, 2025 at 9:56 pm #16936219 | |
svenH-12 |
We’d like to provide a final, detailed update regarding the ongoing German homepage translation issue on hidden link, building on ticket #16931270 and #16935414. ⸻ 🔁 Recap of the Current Situation Despite completely deleting the German translation, deactivating WP Rocket, cleaning the database using all available WPML troubleshooting tools, and then translating the German homepage from scratch via ATE, we consistently experience the following issue: ⸻ ✅ We Have Already: ⸻ ❌ Still Unresolved: ⸻ 🔧 Request: Please investigate or manually reset the ATE job status for this translation on your end — the Job ID is 137050473 — or provide a way for us to: We are happy to provide access, debug info, and logs if needed — this has now been a multi-day blocker and we cannot launch the German version of our homepage until this is resolved. |
| April 15, 2025 at 9:58 pm #16936221 | |
svenH-12 |
Additional Observation: |
| April 17, 2025 at 4:31 am #16941759 | |
Shekhar Bhandari WPML Supporter since 03/2015
Languages: English (English ) Timezone: Asia/Kathmandu (GMT+05:45) |
Hello there, Thank you for contacting WPML support. I’d be happy to assist you with this issue. First, I’d like to apologize for the delay in response — we’ve been handling a high volume of requests. To investigate further, could you please share a few example pages (3–4) where the issue is occurring? Additionally, I’ll need to check your site’s settings directly. For this, I kindly request **temporary access to your site (both wp-admin and FTP credentials)**. You can provide the details in the secure fields located below the comment area when submitting your next reply: This information is kept private and accessible only to you and WPML support staff. Note: Please ensure that you back up your site before sharing credentials. If possible, providing access to a staging/test site is preferred. Looking forward to your response. Thank you |
| April 18, 2025 at 4:24 am #16946182 | |
Hello there, I managed to check the homepage and when we are trying to either save the page in default language or download the translations a 500 server error is happening. It looks like there is some php error happening on your site which is creating the problem, being so can you please follow the below steps and share me the results. 1. Add the following code to your wp-config.php
define('WP_DEBUG', true);
define( 'WP_DEBUG_DISPLAY', true );
https://wpml.org/documentation/support/debugging-wpml/ 2. Repeat the action of creating the problem. 3. Copy and paste the contents of debug.log (log file inside the /wp-content/ directory) here for me to see. Look forward to your reply. Thanks |
| April 18, 2025 at 9:12 am #16946777 | |
svenH-12 |
Hi Shekhar thanks for your help hidden link We also did some quick analysis this morning and asked ChatGPT to analyze parts of the log, and here are two recurring fatal errors that may help pinpoint the issue faster: ⸻ 🧨 1. Fatal Error in WPML ATE Download Error message: First occurrence in log: Possible cause: ⸻ 🧨 2. Fatal Error in WordPress Block Rendering Error message: Occurrences in log: Possible cause: ⚠️ 3. WPML Media Translation – Undefined Array Key Warnings Message: 💡 This may indicate that certain array indices are being assumed when parsing media URLs, but aren’t present—possibly due to missing or malformed media data. ⸻ We hope this helps guide you more quickly toward the source of the problem. Let us know what else we can provide. Best regards, |
| April 18, 2025 at 9:36 am #16946877 | |
svenH-12 |
Additional note and info: After your debugging this morning the main homepage livetube.tv did not show any images anymore in the backend. We have therefore restored the homepage to a version from yesterday evening. Since this is a live site - I have created a clone of the homepage for you to work with so that we do not destroy again or risk anything with the main site. I'd rather like to try to fix this in the live environment than in any stage as we have many interdependencies in our multisite setup which might not fully cloneable. So let's try to fix it here. The copy of the home page for you is: Let me know if you need anything else Thanks |
| April 18, 2025 at 9:47 am #16946936 | |
svenH-12 |
Also, let me just share some of the errors again and some further investigation from our side: [17-Apr-2025 16:58:32 UTC] [18-Apr-2025 04:20:05 UTC] [18-Apr-2025 04:15:52 UTC] We also reviewed some of the homepage content manually and found several Gutenberg blocks using "layout":"flex" as a string value inside the block attributes. Based on the stack trace referring to array_intersect_key() in layout.php, this may be relevant — if the function expects an array but receives a string, it could be causing the fatal error. If the layout attribute is supposed to be an object or array, this might point to a block structure issue introduced by the editor or a third-party plugin. Since the error appears during an ATE (Advanced Translation Editor) download process, it’s also possible that WPML is not handling these block attributes correctly, especially when copying or parsing translated block JSON. It might be treating a string as an array due to a missing structure check or conversion. The "layout":"flex" structure appears in several UAGB container blocks on our homepage. Given that the error in layout.php is triggered when array_intersect_key() receives a string instead of an array, this might indicate a mismatch in expected data types. It’s unclear whether this originates from the block definition (possibly a third-party block like UAGB) or from how WPML parses the block attributes during the ATE process. We’d appreciate your help in identifying whether the issue lies in the source block markup or in the way WPML handles this content during translation downloads. We hope this helps guide you toward identifying the root cause. Let us know if we can assist further or provide block export data for debugging. |
| April 18, 2025 at 11:29 am #16947115 | |
Hello, This issue will require in-depth debugging. Could you please provide a backup of the wp-content folder and the database? This will allow me to replicate the issue on my local setup and investigate further. You can compress the files into a ZIP archive, upload them to Google Drive, and share the download links with me. I've enabled private replies for your convenience. Thank you! |
| April 22, 2025 at 4:05 pm #16956450 | |
svenH-12 |
Hi there, just forgot in my earlier answer to also paste the error we believe ius the cuprit. [18-Apr-2025 09:40:03 UTC] PHP Warning: Undefined array key 0 in /homepages/15/d857208857/htdocs/clickandbuilds/LiveTube/wp-content/plugins/wpml-media-translation/classes/class-wpml-media-attachment-by-url-query.php on line 99 searchwpcro domain was triggered too early. This is usually an indicator for some code in the plugin or theme running too early. Translations should be loaded at the init action or later. Please see Debugging in WordPress for more information. (This message was added in version 6.7.0.) in /homepages/15/d857208857/htdocs/clickandbuilds/LiveTube/wp-includes/functions.php on line 6121 fv-player domain was triggered too early. This is usually an indicator for some code in the plugi Hope this helps in addition to all other info I provided Thanks |
| April 22, 2025 at 4:08 pm #16956455 | |
svenH-12 |
15/d857208857/htdocs/clickandbuilds/LiveTube/wp-includes/functions.php on line 6121 |
| April 24, 2025 at 4:00 pm #16965394 | |
Hi there, I was able to download the backup file successfully. However, since the `wp-content` folder was not zipped, the download process took significantly longer. For future reference, I recommend compressing folders before sending them to make the process quicker and more reliable. After replicating the site locally, I noticed that several plugins and themes were missing from the backup. I installed them manually, and the site is now functioning correctly. I edited the homepage and tested the translation download functionality. Everything worked as expected on my local setup, including media translations with the plugin enabled. This suggests that the issue may be related to an incomplete or incorrect backup. Regarding the error: PHP Fatal error: Uncaught TypeError: array_intersect_key(): Argument #1 ($array) must be of type array, string given in ...sven/wp-includes/block-supports/layout.php:603 This issue occurs even without WPML active. I suggest disabling WPML and refreshing the page—you’ll likely see the error persists. It appears to be related to the container block from the Spectra plugin, so you may want to reach out to their support for further assistance. Since everything is working correctly on my end, I suspect the backup may not have been complete. Could you please generate a fresh backup (preferably zipped) and share it with me so I can attempt to reproduce the issue more accurately? Looking forward to your response. Thanks |
| May 1, 2025 at 10:14 am #16986321 | |
svenH-12 |
Hi Shekhar, Thanks for your investigation and ongoing support. Apologies for the delayed response. With media translations deactivated most of our translations are working well with our current setup. For the stuck translations which not resolve: We discovered that sending eight translations for automatic bulk translation might overwhelm the ATE system when all code also needs to be updated (for the new Spectra Blocks). This causes the ATE system to get stuck, affecting all subsequent translations. When we sent four translations and then another four languages for translation, we were able to resolve the issue. Subsequent translations then work. So it is the amount of code changes due to our migrating to Astra from WP Bakery probably causing the issues and including the code for all the nested containers and formats. Therefore, we’ll first focus on our translations and keep media translations deactivated. Only when we face further problems I will reach out again and we can work on a stage setup to fully reproduce the issues. For your additional info and investigation: For now, I’ll keep the ticket open so that I can report any other issues we encounter. We’ll work diligently on the translations over the coming week. Once again, thank you for your assistance. Please let me know if you require any additional information at this time. |
| May 2, 2025 at 4:23 am #16987875 | |
Hello, Regarding the image blocks, Is it still happening on the site? Can you provide me an example if it's possible? Please note that this ticket will remain open for one week without further activity. If you need additional assistance after that, feel free to start a new chat or ticket — we’ll be happy to assist you further. Thank you. |
The topic ‘[Closed] Translation status not changing to finished’ is closed to new replies.
