The client was experiencing an issue where translated articles were appearing in every domain's article flow instead of being restricted to their respective language domains.
First, we ensured that WPML was active and that the front page template code included the necessary adjustments. We added
'suppress_filters' => 'false'
to the query arguments to ensure that the filters are not suppressed, which is essential for WPML to filter content by language.
Next, we navigated to WPML-> Settings-> Post Type Translation section and set the posts to "Translatable - only show translated items". This ensures that only the posts translated into the current language are displayed on the site.
If you're experiencing a similar issue, we recommend you try the following steps:
1. Activate WPML if it's not already active.
2. Ensure that your front page template code does not suppress filters by adding
to your query arguments.
3. Go to WPML-> Settings-> Post Type Translation and set your posts to "Translatable - only show translated items".
Please note that this solution might be irrelevant if it's outdated or not applicable to your case. If the issue persists, we highly recommend checking related known issues, verifying the version of the permanent fix, and confirming that you have installed the latest versions of themes and plugins. If you still need assistance, please open a new support ticket.
This topic contains 27 replies, has 2 voices.
Last updated by Osama Mersal 1 year, 11 months ago.
Assisted by: Osama Mersal.
| Author | Posts |
| April 29, 2024 at 9:02 am #15575813 | |
Osama Mersal |
Hi, Please go to your theme files/front-page.php. Replace your wp_posts functions with wp_query. Kindly check this guide. (https://developer.wordpress.org/reference/classes/wp_query/) Best regards, |
| April 29, 2024 at 9:54 am #15576233 | |
zachariasD |
Can you try that in the sandbox or do I have to do that? |
| April 29, 2024 at 10:13 am #15576306 | |
Osama Mersal |
Hi, I changed it on the sandbox site. Please check the home page. (hidden link) Best regards, |
| April 29, 2024 at 11:03 am #15576678 | |
zachariasD |
Okey, we tested it on the staging and it did not work hmmm. |
| April 29, 2024 at 11:13 am #15576699 | |
Osama Mersal |
Hi, Please note that the changes I made to the sandbox are to show you how it should work, so you would need to check your custom theme's code to make it work there. Kindly note that custom code/themes are out of our support scope. Please check our support policy. (https://wpml.org/purchase/support-policy/) Best regards, |
| April 29, 2024 at 11:23 am #15576813 | |
zachariasD |
So you did not change wp_posts to wp_query in our theme and made it work? |
| April 29, 2024 at 11:26 am #15576818 | |
Osama Mersal |
Hi, I changed the sandbox site. Here is your code:
<?php
* The template for displaying archive pages.
* Learn more: http://codex.wordpress.org/Template_Hierarchy
* @package nsm
get_header();
$page_id = get_the_ID();
// Current page we are on
$current_page = get_query_var( 'page' ) ? get_query_var( 'page' ) : 1;
// Posts per page
$posts_per_page = 36;
// Total number of posts
$total_posts = wp_count_posts()->publish;
// Loop offset
$offset = ( $current_page - 1 ) * $posts_per_page;
// Loop arguements
$args = array(
'post_type' => 'post',
'posts_per_page' => $posts_per_page,
'offset' => $offset,
$ts_args = array(
'posts_per_page' => 3,
if( $sticky_posts = get_option('sticky_posts') ){
$ts_args['post__in'] = $sticky_posts;
}else{
$ts_args['meta_key'] = 'post_views';
$ts_args['orderby'] = 'meta_value_num';
$ts_args['order'] = 'DESC';
$ts_args['date_query'] = array(
array(
'after' => strtotime( 'last Thursday' ),
if( $excluded_cat = get_field('hidden_category', 'options') ){
$args['category__not_in'] = [ $excluded_cat ];
$ts_args['category__not_in'] = [ $excluded_cat ];
// Total number of pages
$total_pages = ceil( $total_posts / $posts_per_page );
<div class="py-15">
<div class="container">
<div class="row kimura-content-area">
<div class="kimura-content-wrap px-10">
<!-- Top Splash -->
<?php
$ts_posts = get_posts( $ts_args );
if( $ts_posts ){
<div class="text-center mb-20 w-100">
<?php if( function_exists('the_ad_placement') ) { the_ad_placement('980-ads'); } ?>
</div>
<div class="post-top_splash">
<div class="row top_splash">
<?php foreach( $ts_posts as $key => $post ){ ?>
<div class="md-4 post-item-<?php echo $key ?> sm-4">
<?php get_template_part( 'template-parts/post/top_splash' ); ?>
</div>
<?php } ?>
</div>
</div>
<?php wp_reset_postdata(); ?>
<?php } ?>
</div>
<!-- Content -->
<?php if( !is_paged() ){ ?>
<div class="entry-content front-page_content tc-d mb-20 bg-p px-20 py-20">
<?php echo get_the_content( null, false, $page_id ); ?>
</div>
<?php } ?>
<!-- Loop A -->
<?php
// The posts
$posts = get_posts( $args );
if ( $posts ){
<?php if( $loop_a = array_slice( $posts, 0, 16 ) ){ ?>
<div class="row post-loop_a">
<div class="kimura-content-wrap-inner px-10">
<?php foreach( $loop_a as $key => $post ){ ?>
<div class="post-item post-item-<?php echo $key ?>">
<?php get_template_part( 'template-parts/post/layouts/layout-1' ); ?>
</div>
<?php
// we are leaving this increase we needed to change for mobile and desktop
if( wp_is_mobile() ){
if($key % 2 == 1 && $key != count($loop_a) - 1){
echo '<div class="text-center mb-20 w-100">';
if( function_exists('the_ad_placement') ) { the_ad_placement('640-ads'); }
echo '</div>';
}else{
if( $key % 2 == 1 && $key != count($loop_a) - 1){
echo '</div>';
<?php } ?>
</div>
<?php if( is_active_sidebar('sidebar-2') ){ ?>
<div class="kimura-sidebar sidebar-2 mb-20 f-1 px-10 sidebar-sticky d-none d-md-block">
<div>
<?php dynamic_sidebar( 'sidebar-2' ); ?>
</div>
</div>
<?php } ?>
</div>
<?php } ?>
<!-- Loop B -->
<?php if( $loop_b = array_slice( $posts, 16 ) ){ ?>
<div class="row post-loop_b">
<?php foreach( $loop_b as $key => $post ){ ?>
<?php
if( $key % 2 == 0 ){
echo '<div class="text-center mb-20 w-100 px-10">';
echo '</div>';
}else{
if( $key % 4 == 0 ){
echo '</div>';
<div class="post-item post-item-<?php echo $key ?> sm-6">
</div>
<?php
if( $key == count($loop_b) - 1 ){
echo '</div>';
<?php } ?>
</div>
<?php } ?>
<?php } ?>
</div>
<?php if( is_active_sidebar('sidebar-1') ){ ?>
<div class="kimura-sidebar f-1 px-10 mb-20 d-none d-lg-block">
<?php dynamic_sidebar( 'sidebar-1' ); ?>
</div>
<?php } ?>
</div>
<?php if( $posts ){ ?>
<?php if( $current_page == 1 ){ ?>
<div class="d-flex ai-c jc-e mt-20">
<a id="page-next" class="btn btn-primary w-100 w-sm-auto" href="<?php echo home_url() ?>/page/2/">Nästa sida</a>
</div>
<div class="kimura-sponsors my-20 text-center">
<span class="d-i-block bg-p tc-d fw-sb fs-14 px-10 py-5">Samarbetspartners</span>
</div>
<div class="text-center text-sm-left">
<a class="mr-5 mb-5 d-i-block" href="<em><u>hidden link</u></em>"><img src="<em><u>hidden link</u></em>" title="Matspar index logo" width="300" height="60"></a>
<a class="mr-5 mb-5 d-i-block" href="<em><u>hidden link</u></em>"><img src="<em><u>hidden link</u></em>" title="Unibet index logo" width="300" height="60"></a>
<a class="mr-5 mb-5 d-i-block" href="<em><u>hidden link</u></em>"><img src="<em><u>hidden link</u></em>" title="Pluto index logo" width="300" height="60"></a>
<a class="mr-5 mb-5 d-i-block" href="<em><u>hidden link</u></em>"><img src="<em><u>hidden link</u></em>" title="Bettingcom index logo" width="300" height="60"></a>
<a class="mr-5 mb-5 d-i-block" href="<em><u>hidden link</u></em>"><img src="<em><u>hidden link</u></em>" title="sportpanelen" alt="sportpanelen" width="300" height="60"></a>
<a class="mr-5 mb-5 d-i-block" href="<em><u>hidden link</u></em>"><img src="<em><u>hidden link</u></em>" title="mmabetz" alt="mmabetz" width="300" height="60"></a>
</div>
<?php }else{ ?>
<?php Nsm_Helper::pagination( [ 'type' => 'post', 'total' => $total_pages ], $current_page ); ?>
<?php } ?>
<?php } ?>
</div>
</div>
<?php get_footer(); ?>
and here is the current code
<?php
* @package nsm
get_header();
$current_page = max(1, get_query_var('paged'));
// Posts per page
// Query for regular posts
$args = array(
'paged' => $current_page,
$main_query = new WP_Query($args);
// Query for top splash posts
$ts_args = array(
if ($sticky_posts = get_option('sticky_posts')) {
$ts_args['orderby'] = 'post__in';
} else {
array('after' => '1 week ago'),
if ($excluded_cat = get_field('hidden_category', 'options')) {
$args['category__not_in'] = $ts_args['category__not_in'] = [$excluded_cat];
$ts_query = new WP_Query($ts_args);
<div class="py-15">
<!-- Top Splash -->
<?php if ($ts_query->have_posts()) : ?>
<?php if (function_exists('the_ad_placement')) the_ad_placement('980-ads'); ?>
</div>
<?php while ($ts_query->have_posts()) : $ts_query->the_post(); ?>
<div class="col-md-4 post-item-<?php echo $ts_query->current_post; ?> col-sm-4">
<?php get_template_part('template-parts/post/top_splash'); ?>
</div>
<?php endwhile; wp_reset_postdata(); ?>
</div>
</div>
<?php endif; ?>
</div>
<!-- Main Content Loop -->
<?php if ($main_query->have_posts()) : ?>
<?php while ($main_query->have_posts()) : $main_query->the_post(); ?>
<div class="post-item post-item-<?php echo $main_query->current_post; ?>">
<?php get_template_part('template-parts/post/layouts/layout-1'); ?>
<?php if (($main_query->current_post % 2 == 1) && !$main_query->is_last()) : ?>
<?php if (function_exists('the_ad_placement')) the_ad_placement('640-ads'); ?>
</div>
<?php endif; ?>
<?php endwhile; ?>
<!-- Pagination Logic -->
<?php echo paginate_links(array('total' => $main_query->max_num_pages)); ?>
<?php endif; ?>
</div>
</div>
<?php if (is_active_sidebar('sidebar-1')) : ?>
<?php dynamic_sidebar('sidebar-1'); ?>
</div>
<?php endif; ?>
</div>
</div>
</div>
Best regards, |
| April 30, 2024 at 6:12 am #15579294 | |
zachariasD |
Dosent seem to work. This issue isnt new: hidden link Do you have any colleagues that have faced the same issue in the support? |
| April 30, 2024 at 6:22 am #15579317 | |
Osama Mersal |
Hi, Please check this reply. (https://wpml.org/forums/topic/query-posts-return-all-language/#post-14172683) Also, please check this guide. (https://wpml.org/documentation/support/debugging-theme-compatibility/#issue-wp_queryargs-or-get_postsargs-doesnt-filter-out-correct-posts-ids-for-the-current-language) Best regards, |
| April 30, 2024 at 6:26 am #15579330 | |
zachariasD |
Yes but it dosent only appear on the index page, all URL's all tha pages appear under all domains. |
| April 30, 2024 at 6:50 am #15579410 | |
Osama Mersal |
Hi, On your staging site, WPML was not active, and the front page template code was not changed. However, I added the 'suppress_filters' => 'false' to your args. (Kindly check the attached screenshot) Please check if the translated posts appear on the home page. Best regards, |
| April 30, 2024 at 7:06 am #15579494 | |
zachariasD |
Now it works, the translations show on each page and now double anymore, but all old posts (that are not translated) still appear on each site. How do we solve this? |
| April 30, 2024 at 7:13 am #15579556 | |
Osama Mersal |
Hi, In order to show the posts/pages in only the current language, please go to WPML-> Settings-> Post Type Translation section and set the posts to "Translatable - only show translated items". I did that on your staging site. Please check the English home page. (hidden link) Best regards, |
| May 3, 2024 at 6:28 am #15589538 | |
zachariasD |
Thank you for the help! Everything is solved now |
