The Global Section present in the Home Page was not translatable.
If you're experiencing a similar issue where a specific Global Section is not translatable, we recommend manually inserting the content into the home page and then translating it. This approach was effective in resolving the issue on the client's website.
Please note that this solution might be irrelevant if it's outdated or not applicable to your case. We highly recommend checking related known issues at https://wpml.org/known-issues/, verifying the version of the permanent fix, and confirming that you have installed the latest versions of themes and plugins. If the problem persists, please open a new support ticket.
Last updated by Lucas Vidal de Andrade 1 year, 7 months ago.
September 20, 2024 at 3:00 pm #16203477
ingridaK-3
Global section present in the Home Page not translatable.
September 20, 2024 at 7:18 pm #16203982
WPML Supporter since 11/2023
Hey there.
I’m still checking on your issue.
To provide you with some context, the element that is showing untranslated in the home page is a global template. Even after recreating the translation and updating the translation of the home page, i wasn't able to make it work as expected. I’ll keep testing and perhaps get a second opinion.
I’ll get back to you as soon as I have new information on it.
September 23, 2024 at 11:21 am #16209189
Hey there,
Can you please share your access details once more? I'm still checking on a copy of your website.
IMPORTANT
- If you do not see the wp-admin/FTP fields this means your post & website login details will be made PUBLIC. DO NOT post your website details unless you see the required wp-admin/FTP fields. If you do not, please ask me to enable the private box. The private box looks like this:
September 23, 2024 at 11:29 am #16209213
ingridaK-3
I see no private box to provide access details.
I think you have made duplicate on Friday and already installed those plugins you are mentioning? At least you have asked that and I said - whatever it takes to fix this.
September 23, 2024 at 5:37 pm #16211272
Hey there,
Can you please check again? It should look something like that:
The credentials you sent are not available to me anymore. I need access to your website, so I can ask for a second opinion with my developer colleagues.
September 24, 2024 at 12:26 pm #16214734
Hey,
I got this message: "ERROR: The username or password you entered is incorrect. Lost your password?"
Can you please check? I'm sorry for the back and forth, but I need access to a fresh copy, so I can forward it to our devs.
September 24, 2024 at 2:22 pm #16215552
This is indeed taking some back and forth, if I'm interpreting your passwords correctly. The credentials you sent are, once again, invalid. I'm talking about the WPML-Admin user. Please verify if they're working before sharing access, this way we can save some time.
September 24, 2024 at 6:33 pm #16217190
Thank you so much. I'm getting a second opinion with my developer colleagues and will get back to you as soon as I can. Thanks for your patience.
September 25, 2024 at 12:41 pm #16220343
Hey there,
I was able to fix the issue directly on your website. The problem we were having was that the specific Global Section was not being translated. It seemed to be specific to that template.
I directly inserted the content in the home page and translated it. Please check and let me know if now it's working as expected now.
