I have a UABB Advance Post module for Beaver Builder on the homepage of hidden link. It is pulling custom fields from a custom post containing testimonials. These are rotating with a carousel effect.
For some reason, when I switch into Arabic, the text disappears. I suspect that it could be something to do with the swapping of direction of layout, maybe if the javascript is moving it offscreen and not putting it back in the right position.
I realise that this could be an issue with the UABB code, but it's frustrating because that module does exactly what I want. If I need to speak to the UABB support, please let me know what I should ask them. Thank you!
Also, if you need access to the WP dashboard, let me know and I can provide that.
After adding the CSS, please clear the site cache and then check if the issue is resolved.
I also suggest contacting the plugin authors and sharing the issue with them.
Kind regards,
Mohamed
Manage Cookie Consent
Functional
Always active
Preferences
Statistics
Marketing
