The client is experiencing an issue where switching to the Spanish language on their website redirects them to the homepage instead of the translated Activity page. They have set up WPML and translated a custom post type (CPT) 'Cooking Classes' but encounter redirection and 'Invalid post type' errors.
We recommend the following steps to troubleshoot and resolve the issue:
Ensure that the custom post type 'Tours' is properly configured for translation in WPML. Go to ACF > POST TYPES > TOURS > EDIT, select WPML translation Editor, and click the + sign to translate it.
If these steps do not resolve the issue or if you encounter further problems, it might be due to outdated information or a different configuration. We highly recommend checking related known issues at https://wpml.org/known-issues/, verifying the version of the permanent fix, and confirming that you have installed the latest versions of themes and plugins. If the problem persists, please open a new support ticket at WPML support forum for further assistance.
This topic contains 15 replies, has 3 voices.
Last updated by Andreas W. 1 year, 7 months ago.
June 13, 2024 at 6:18 pm #15737576
odisseasK
I have a website built in DIVI THEME with DIVI Builder. I installed the following plugins: Yoast SEO, WPML core plugin, WPML Translation Management, WPML String Translation add-on, WPML SEO add-on. I have created 3 custom post types - Activities, Tours, Accommodations. I am trying to translate one Activity to see if it is working correctly. After I installed the plugins, I took the following steps to translate one specific Activity 'Cooking Classes': 1. SETUP WPML 2. WPML > Languages - set up site language, translation languages, menu switcher locations 3. WPML > Settings > Εnableδ translatable items 4. WPML → Translation Management and scrolled down to Select activity for translation. 5. translation Que (WPML > Translations) and translated the content.
When I go to hidden link and switch to Spanish Language, it redirects me to the Homepage.
Why does switching to the Spanish language redirect me to the homepage instead of the translated Activity page?
Is there a step I missed in the translation process for custom post types in WPML?
June 13, 2024 at 6:37 pm #15737608
Lucas Vidal de Andrade
WPML Supporter since 11/2023
Please make sure that in WPML > Settings your custom post types are marked as translatable.
https://wpml.org/documentation/getting-started-guide/translating-custom-posts/
Besides that,I checked your debug info and noticed that your website doesn't have the minimum memory required for WPML to work. WPML requires a memory limit of at least 128MB while 256MB is recommended. See https://wpml.org/home/minimum-requirements/ for detailed information. You can set WP Memory Limit in your wp-config.php file by adding the following code:
define( 'WP_MAX_MEMORY_LIMIT', '512M' );
See:
https://wordpress.org/support/article/editing-wp-config-php/#increasing-memory-allocated-to-php
for details. Increasing WP Memory may help improve the performance and sometimes also help resolving such issues.
If that does not help, one of my colleagues will soon come to continue support.
June 13, 2024 at 7:20 pm #15737663
odisseasK
Thanks Lucas for your support.
I had already set the limits to 128 but now I changed it to 256.
Please let me know if you still see the error
June 13, 2024 at 9:04 pm #15737816
If you revise the Spanish menu, it actually seems as if those contents were not yet published.
Please revise the status of your translated content.
It may happen that translations are saved as draft, if at the moment that you began translating the content the original content was still saved as draft.
Also, in case you use "Translate Everything Automatically" by default the translations are saved as a draft. You will need to complete a review at WPML > Translations first before they get published. This can be altered for new translations using the options on WPML > Settings > Automatic Translation.
June 14, 2024 at 9:35 am #15739412
odisseasK
Hello Andreas.
I translate everything myself.
I translated a custom post type instance.
I visited the english version on the website, clicked the spanish flag and got redirected to the home page
June 14, 2024 at 6:42 pm #15741135
IMPORTANT
Video:
June 15, 2024 at 9:43 am #15741576
If I switch to the translated CPT on the list view or the WordPress Editor, I get the message "Invalid post type".
Is it possible to temporarily disable plugins on this install and maybe even switch the theme for testing purposes?
June 15, 2024 at 12:50 pm #15741727
odisseasK
I have only translated two post types in the website.
The first one is this ( STAY > Blue Sky Cave house Oia )
The other one is this (ENJOY > Cooking Classes )
If you visit those two instances in English version and HOVER over the Spanish Flag, you see at the bottom left that the link is the correct one.
But when you CLICK on the Spanish flag on
you get redirected to the HOME PAGE
And when you CLICK on the Spanish flag on
is tells you that there are no results for this page.
YES you can disable plugins or switch themes. This is a testing website. Thank you for your support
June 15, 2024 at 6:29 pm #15741994
On ACF > Post Type click "Edit" and then translate the post type.
I did this already for "Activities" now:
Unrelated to the issue:
The ACF Field Group Post Type should always be set to "Not translatable".
June 16, 2024 at 8:02 pm #15743034
odisseasK
Can you please explain exactly what you did ?
The spanish translation doesn't appear as it should.
The post type is assigned to a Divi Theme Builder Layout.
Why doesn't the Spanish version render the layout as well?:
June 16, 2024 at 8:03 pm #15743035
odisseasK
Also pay attention to the footer in Spanish. It is broken
June 17, 2024 at 9:56 am #15744448
odisseasK
I deleted some Divi Theme Builder layouts and I received a critical error coming from WPML SEO Multilingual.
Maybe it is related to the issue we are discussing?
New threads created by Andreas W. and linked to this one are listed below:
https://wpml.org/forums/topic/split-issue-translating-divi-theme-builder-layouts/
June 18, 2024 at 4:30 pm #15750265
I went to On ACF > Post Type clicked the "Edit" option on the post and then used the UI to create the translation for the post type.
This solves the main issue of this ticket about CPTs not showing up in the second language.
Let me know if you still have questions about this as this is not yet covered by our documentation.
We only released the following post about it:
https://wpml.org/compatibility/2024/04/acfml-2-1-0-translate-labels-for-acf-custom-posts-taxonomies-options-pages/
Regarding your last two comments, take note that this is a different issue and we only handle one issue per ticket. I am splitting this new issue about Divi Templates into a new ticket and will follow up there with you shortly.
You will receive an e-mail notification once I reply to the new ticket.
June 18, 2024 at 4:58 pm #15750387
odisseasK
So if I want to repeat what you did for the Activities ( ex. the TOURS ) , I go to ACF > POST TYPES > go to TOURS > EDIT > select WPML translation Editor and click the + sign to translate it?
June 18, 2024 at 4:59 pm #15750402
odisseasK
Thanks for your feedback on Divi Layouts. I will wait for your new ticket.
Please have in mind that I want the Spanish translation on every post to be assigned to the same template assigned to the English one...and I also want to change the button links on the Spanish version.
