9:00 – 18:00 | 9:00 – 18:00 | 9:00 – 18:00 | 9:00 – 18:00 | 9:00 – 18:00 | - | - |
Last updated by Osama Mersal 1 year, 10 months ago.
Assisted by: Osama Mersal.
August 24, 2023 at 6:50 pm #14287891 | |
markS-91 |
The site I am testing WPML on is hidden link Do you have any instructions showing how to do all of the steps required? The staging pages that we are testing so far are: |
August 27, 2023 at 7:10 am #14295563 | |
Osama Mersal WPML Supporter since 02/2020
Languages: English (English ) Arabic (العربية ) Timezone: Africa/Cairo (GMT+03:00) |
Hi, Thanks for contacting WPML forums support. I'll be glad to help you today. First of all, sorry for the late reply due to a higher workload. 1) I would need to look closely at your site, so I would need to request temporary access (WP-Admin and FTP) Your next answer will be private, which means only you and I can access it. ❌ Please backup your database and website ❌ ✙ I would need your permission to de-activate and re-activate the Plugins and the Theme and change configurations on the site. This is also a reason the backup is critical. ✙ I also need your permission to take a local copy of your site to debug the issue without affecting your live site. 2) It's not related to the issue, but according to your Debug.info, the WP memory limit needs to be increased. PHP memory is fine, but WordPress uses 40Mb as default. The minimum requirements for WPML are 128 MB. (Kindly check this page https://wpml.org/home/minimum-requirements/) You can increase it by adding the following code in your wp-config.php file right before the /* That's all, stop editing! Happy publishing. */ line: /* Memory Limit */ define('WP_MEMORY_LIMIT', '256M'); define( 'WP_MAX_MEMORY_LIMIT', '256M'); Best regards, |
August 28, 2023 at 5:37 am #14297177 | |
Hi, 1) Thanks for the access details. I've checked the mentioned page, and the untranslated section is an Elementor template, so you need to translate this template. (FSC Locations Listings) Also, please note that you didn't translate the Footer and Header templates. Kindly check our guide to know more about translating Elementor templates. (https://wpml.org/documentation/plugins-compatibility/elementor/) 2) The location post type is not set to be translatable. Please go to WPML-> Setting-> Post Type Translation section, and set the "FSC Location Pages (locations)" post type to be translatable. After that, please update the location post in the default language and translate it. Best regards, |
August 28, 2023 at 3:52 pm #14302159 | |
markS-91 |
Thanks for your help! I was able to get most things translated except sections of this page |
August 28, 2023 at 3:58 pm #14302187 | |
Hi, Please edit the page in the default language, scroll down to the "Multilingual Content Setup" section, set the needed fields to be translatable or copied, and save. (hidden link) After that, please update the page in the default language and translate it. Alternatively, you can translate the location posts manually. Kindly check our guide about manual translation. (https://wpml.org/documentation/translating-your-contents/using-different-translation-editors-for-different-pages/) Best regards, |
August 28, 2023 at 4:26 pm #14302305 | |
markS-91 |
Getting closer, still not getting the middle part of the page starting with this block |
August 28, 2023 at 4:43 pm #14302521 | |
Hi, I set some fields to be copied. Please check the page and let me know if it works correctly. Best regards, |
August 28, 2023 at 4:57 pm #14302589 | |
markS-91 |
That is MUCH better. |
August 28, 2023 at 5:21 pm #14302603 | |
Hi, I translated the string by translating the Elementor single post template. For the accordion, you need to translate the used categories in the loop in order to fix the issue. As a quick workaround, I set the taxonomies and posts as "Translatable - use translation if available or fallback to default language". Best regards, |
August 28, 2023 at 7:41 pm #14303131 | |
markS-91 |
I am feeling like this is very hit and miss, so I must not understand it. Especially on the FSC Services items being translated. Some of them are showing in Spanish, some are not. Best I can tell they are translated. Also some photos being copied over, some are not. It also could be stuff is cached somewhere, but not sure how to tell. Sorry I am missing something and not understanding what changes I need to make, so I can't repeat anything. |
August 29, 2023 at 5:50 am #14303889 | |
Hi, In order to fix the issue of the accordion section, you need to translate the Services, Locations, and Service Categories. After that, the accordion section will show the correct posts in Spanish. For the images, please make sure to select the "Duplicate featured image to translations" option when translating a post. Best regards, |
September 1, 2023 at 8:20 pm #14328985 | |
markS-91 |
It looks like I got them all, but it also seems like it takes some amount of time, way more than a minute or two for things to show up on the translated page after I translate all the parts that are used to build the page. Is there something I am missing that clears a cache within one of these programs or somewhere else. |
September 2, 2023 at 9:54 am #14329899 | |
Hi, I couldn't check the page you shared because it showed me a critical error. Would you please check the page and let me know when it works to check it? Thanks, |
The topic ‘[Closed] Using WPML with site built with Elementor and Pods plugins’ is closed to new replies.
