| - | 9:00 – 12:00 | 9:00 – 12:00 | 9:00 – 12:00 | 9:00 – 12:00 | 9:00 – 12:00 | - |
| - | 13:00 – 18:00 | 13:00 – 18:00 | 13:00 – 18:00 | 13:00 – 18:00 | 13:00 – 18:00 | - |
Related documentation:
This topic contains 18 replies, has 2 voices.
Last updated by Kor 1 year, 9 months ago.
| Author | Posts |
| March 13, 2024 at 3:34 pm #15405088 | |
cecileG |
WCML updates breaks UPS and Ultimate Gift Card plugin |
| March 13, 2024 at 3:49 pm #15405226 | |
Kor WPML Supporter since 08/2022
Languages: English (English ) Timezone: Asia/Singapore (GMT+08:00) |
Thanks for your reply. Here is the ticket and I will need to closely examine your website. Therefore, I will require temporary access (WP-Admin and FTP) to a test site where the problem has been replicated, if possible. This will enable me to provide better assistance and determine if any configurations need to be modified. Please note that it is important to have a backup for security purposes and to prevent any potential data loss. You can use the UpdraftPlus plugin (https://wordpress.org/plugins/updraftplus/) to fulfill your backup requirements. Your upcoming reply will be treated with confidentiality and will only be visible to you and me. ✙ To resolve the issue, I may need your consent to deactivate and reactivate plugins and the theme, as well as make configuration changes on the site if necessary. This emphasizes the significance of having a backup. |
| March 14, 2024 at 5:33 pm #15411764 | |
Thank you for responding. Could you please revert the fix and provide details on the actions you took to resolve the issue? Specifically, I need to know which file you modified and the line of code you added to implement the fix. Once I have this information, I will compile a report and escalate the matter to our 2nd Tier Support for further investigation into the custom fix you applied to resolve the issue. |
| March 15, 2024 at 8:57 am #15413308 | |
cecileG |
Hi, It's done. $product_id = apply_filters( 'woocommerce_cart_item_product_id', $cart_item['product_id'], $cart_item, $cart_item_key ); Now, if you add a product to the cart (like "A demi-mot"), and try to access th cart page while logged in, there's a timeout : PHP Fatal error: Maximum execution time of 30 seconds exceeded in /wp-content/plugins/sitepress-multilingual-cms/classes/utilities/class-debug-backtrace.php on line 137 When I comment lines 1765 and 1801, I no longer have this timeout error but I have the error with class ups_carrier not found as indicated in my previous message. And I have these errors since I updated WCML. Before everythings used to work fine. Hope you can find a solution. |
| March 15, 2024 at 2:06 pm #15414749 | |
Thank you for your response. It appears that the UPS and Ultimate Gift Card plugins have not undergone full testing or validation for compatibility with WPML, as they are not listed in our repository at https://wpml.org/plugin/. This indicates that our developers have not specifically tested these plugins with WPML. However, it's worth noting that some plugins not listed in our repository may still be partially compatible or have the potential for compatibility with WPML. I suggest reaching out to the support team or developers of the respective plugins to inquire about their compatibility status with WPML. If the plugins are found to be incompatible, I recommend suggesting that they consider joining our 'Go Global' program (https://wpml.org/documentation/support/go-global-program/), where our Compatibility developers can assist them in ensuring their product becomes fully compatible with WPML, at no cost. For now, what you can do would be to downgrade the WCML plugin so that it is compatible with the UPS and Ultimate Gift Card plugins. You can download the older versions here https://wpml.org/download/woocommerce-multilingual-multicurrency/?section=changelog . Then, once the plugin is fully tested and compatible, you can then update the WCML or UPS and Ultimate Gift Card plugin to the latest version. It depends on where the fix is applied. |
| March 15, 2024 at 3:36 pm #15415199 | |
cecileG |
Hi, Thanks for your reply. {code} to : {code} Could you explain what this do ? I replaced the code by the old one and I have no error. Thank you |
| March 15, 2024 at 3:43 pm #15415236 | |
Thanks for your reply. Could you please be more specific about which file and line number you're referring to the WCML_WC_Shipping class? Also, you mentioned about this. I had commented lines 1765 and 1801 of the file wp-content/plugins/woo-gift-cards-lite/public/class-woocommerce-gift-cards-lite-public.php : $product_id = apply_filters( 'woocommerce_cart_item_product_id', $cart_item['product_id'], $cart_item, $cart_item_key ); Do you mean you need to edit both the WCML_WC_Shipping class and wp-content/plugins/woo-gift-cards-lite/public/class-woocommerce-gift-cards-lite-public.php file to fix the issue you had there? |
| March 15, 2024 at 4:13 pm #15415324 | |
cecileG |
The file is /wp-content/plugins/woocommerce-multilingual/inc/class-wcml-wc-shipping.php, line 43 (in version 5.3.5). When I edit only the file class-woocommerce-gift-cards-lite-public.php, I can fix the timeout on the cart page (without editing WCML). But then I have an another error with the giftcard product and the UPS plugin (error "ups_carrier" class not found). But when I edit only the WCML_WC_Shipping class and replace the new code by the old one in add_hooks method, I can fix all the errors. Thank you |
| March 15, 2024 at 7:18 pm #15415914 | |
Thank you for responding. Could you please undo the modifications made on the staging Website at hidden link? I require the issue to be replicated on the cart page after adding this product: hidden link This will enable me to generate a report for our 2nd Tier Support team to investigate further. |
| March 18, 2024 at 8:29 am #15419498 | |
cecileG |
Hi, There is no more custom code in the plugins. I already revert the custom fix I added in woo-gift-cards-lite plugin last week. And I didn't added the custom fix in WCML on the staging. To replicate the bug : Thank you |
| March 18, 2024 at 9:48 am #15419896 | |
Thanks for your reply. I've retested again and it seems to work fine as shown in this screen recording hidden link . Could you please try using another browser and let me know if you're still encountering the same issue? Also, it would be helpful if you could record a short screen recording while you try to replicate the issue. |
| March 18, 2024 at 2:45 pm #15421833 | |
cecileG |
Hi, Here the recording where I have the problem : hidden link Could you try with a product with delivery too : hidden link ? And if still not the error, could you try to add a valid address on checkout page, and go back to cart page to test ? Thank you |
| March 18, 2024 at 3:25 pm #15422232 | |
Thanks for your reply. Could you please try adding a product to the cart using the account that you've created for me? It's still working fine when I tested it. hidden link Let me know how it goes. |
| March 18, 2024 at 4:53 pm #15422643 | |
cecileG |
I have the same problem with your test account. Thank you |
| March 18, 2024 at 4:58 pm #15422652 | |
Thanks for your reply. It's probably some sort of restriction from your server. It's still working fine when I tested it here hidden link . |
The topic ‘[Closed] WCML updates breaks UPS and Ultimate Gift Card plugin’ is closed to new replies.
