The client is developing a site and wants to add the Danish language. They encountered issues where 'Validate on save' shows 'Not valid', and the backend won't open after attempting to deactivate WPML.
First, ensure that the subdomain for the Danish language points correctly to the root folder. This involves configuring the DNS settings. You can find detailed instructions on how to do this here: https://wpml.org/documentation/getting-started-guide/language-setup/language-url-options/how-to-use-wpml-with-different-domains-per-language/#2-configure-the-dns-settings.
Once the DNS settings are correctly configured, try to validate the site again. If the problem persists or the solution provided here is not applicable due to being outdated or not matching your case, we recommend opening a new support ticket. Additionally, please check related known issues at https://wpml.org/known-issues/, verify the version of the permanent fix, and confirm that you have installed the latest versions of themes and plugins. For further assistance, you can also contact our support team directly at the WPML support forum.
Last updated by 1 year, 10 months ago.
Assisted by: Marcel.
