If you're developing a site and want to enable switching the WordPress account interface to the user's language of preference using WPML, but find that when a user registers with a non-English language and logs into their control panel, the interface remains in English.
We recommend adding the following custom code to your theme's functions.php file:
add_action('user_register', function($user_id) {<br />    $current_language = function_exists('wpml_get_current_language') ? wpml_get_current_language() : get_locale();<br /><br />    if (!empty($current_language)) {<br />        update_user_meta($user_id, 'locale', $current_language);<br />        remove_action('personal_options_update', 'wpml_update_user_locale'); <br />        wp_update_user([<br />            'ID'     => $user_id,<br />            'locale' => $current_language<br />        ]);<br />    }<br />}, 20);
Please test this code in a staging environment before applying it to a live site, as this custom code is a courtesy and is not officially supported by us.
If this solution does not resolve your issue, or if it seems outdated or irrelevant to your case, we highly recommend checking related known issues at https://wpml.org/known-issues/, verifying the version of the permanent fix, and confirming that you have installed the latest versions of themes and plugins. If needed, please open a new support ticket at our support forum.
Last updated by Osama Mersal 4 months, 1 week ago.
Assisted by: Osama Mersal.
February 12, 2025 at 4:08 am #16693995
veraB-9
I am developing a site and want to enable switching the WordPress account interface to the user's language of preference using WPML.
When a user registers with a non-English language and logs into their control panel, the interface is still in English.
How can I enable the WordPress account interface to switch to the user's preferred language?
February 12, 2025 at 11:51 am #16696186
Osama Mersal
WPML Supporter since 02/2020
1) Please go to Users -> Profile, change the language using the language dropdown menu, and update the profile.
Osama
February 13, 2025 at 11:51 am #16701597
veraB-9
none
February 13, 2025 at 12:07 pm #16701779
Osama Mersal
Please share a screenshot of the language field inside the Profile edit screen.
Osama
February 14, 2025 at 9:39 pm #16708064
veraB-9
Thank you, Osama.
I am including the screenshots (language field as well). The particular test story is:
1) a new user registers choosing Russian language (using WPML-provided switch on the bottom of the registration page)
2) subsequent login reveals English interface of the WP account
3) the language in the language field inside the Profile edit screen is also English
So, the language information chosen by a user is not being transmitted
Thank you!
February 15, 2025 at 1:23 pm #16708985
Osama Mersal
Thanks for your update. I would need to look closely at your site, so I would need to request temporary access (WP-Admin and FTP)
Osama
February 16, 2025 at 4:40 pm #16711033
Osama Mersal
Thanks for the access details. Please check the provided account capabilities, as I can't install a new plugin to take a local package.
Osama
February 18, 2025 at 2:40 pm #16719667
veraB-9
Thanks, Osama.
Our developer told me that there are differences (hardwired in WordPress) in privileges between different users assigned to "Administrator" roles, with the main user with ID1 still having more privileges. I've assigned your account the highest privilege possible (Administrator). If this does not work for a particular purpose, the least troublesome way would be for me to install the required plugin for you. What is the plugin address?
Thank you!
February 19, 2025 at 8:25 am #16722637
Osama Mersal
Thanks for your update. Please install this hidden link">plugin, create a backup, and let me know to download it.
Osama
February 20, 2025 at 11:20 pm #16731750
veraB-9
Thank you, Osama.
Done!
February 21, 2025 at 2:23 pm #16734098
Osama Mersal
Thanks for creating the package. I installed a local copy of your site and was able to fix the issue by adding the following code to the functions.php file.
        wp_update_user([
            'ID'     => $user_id,
}, 20);
Please note that this custom code is a courtesy and is not officially supported by the WPML team. Please test it in a staging environment before applying it to a live site.
Osama
February 25, 2025 at 1:16 pm #16745958
veraB-9
Thank you, Osama.
The code is implemented and we are much closer to completeness.
Still, there are peculiarites of how the language switches function acroiss the site and contexts.
We have 3 types of language switches (screenshots with the respective numbers in filenames):
1) main top switch on the frontpage / other content pages of the site;
2) switch in the user settings of the dashboard (WP native one)
3) top switch in the dashboard
What is happening is that switch #1 works fine on the sites content but does noty affect the dashboard
Switch #2 changes the user's language environment in the dashboard
Switch #3 helps ADMINS to navigate multi-langauge content in the dashboard (it is not helpful to the regular user, though).
So, the ideal world solution would be to have switch #1 as a "Master Switch" to affect everything, from site content to the dashboard environment. But we realize this may or may not be possible. Given the current functionality, hiding the switch #3 from a regular user (not admin) may be a working solution. Or maybe we are missing something and you can suggest a better solution?
Thank you!
February 25, 2025 at 1:26 pm #16746069
Osama Mersal
1) This front-end language switcher only works on the front-end content.
2) This is not a language switcher; it's an option that says which language the strings of the dashboard will appear to that user. It's unrelated to the content, pages, posts, products, etc.
3) This dashboard language switcher switches the language in the dashboard to see different content in different languages.
The front-end language switcher can't be a master switcher for the front-end and dashboard.
Osama
February 26, 2025 at 10:17 am #16750195
veraB-9
Thank you, Osama.
To our latter question from the previous message ("hiding the switch #3 from a regular user (not admin)") - this may improve useability for the confused regular user. Could you suggest a way / a script to hide the top language switch in the dashboard from the regular (non-privileged) user?
Thank you always!
February 26, 2025 at 10:54 am #16750556
Osama Mersal
There is no setting for hiding it, but you can write a function to achieve that. I'm afraid we don't have one ready for that.
Osama
