Last updated by Long Nguyen 1 year, 3 months ago.
Assisted by: Long Nguyen.
April 17, 2024 at 3:23 am #15528903
andreaB-8
Near to complete in right way.
I create new page with editor as you wrote me
But in section
Our treatments (where I've images sliders)
When I click on images blocks, links are still in Italian version
Etc...
Please help me fixing!
April 17, 2024 at 3:31 am #15528908
Long Nguyen
WPML Supporter since 02/2022
Hi Andrea,
I see the link in the image slider is the field "Read more link" when you edit the service post. I follow steps below to translate the link:
1. Go to WPML > Settings > Custom Fields Translation > Click on "Show system fields".
2. Search for the field "_bunch_services_settings" and set the preference to "Translate".
3. Go to Services > Edit a service post > Click on Update > Update the translation.
4. In the Advanced Translation Editor > Search for the keyword "http" and translate the URL.
Now you can see it works correctly in the frontend. Please check the attached screenshots.
Refer documentation
https://wpml.org/faq/how-to-translate-urls-shortcodes-and-html-attributes-using-the-advanced-translation-editor/
The element Our Services in the builder is created by the theme "Doxwell" (hidden link). This theme isn't available in our list of compatible themes https://wpml.org/theme/
I also suggest you contact the theme author and ask them to join our Go Global program where our Compatibility developers will help them to make their product compatible with WPML.
https://wpml.org/documentation/support/go-global-program/
The topic ‘[Closed] When I click on images blocks, links are still in Italian version’ is closed to new replies.
