The client reported that WooCommerce product images and some section images were not displaying after translating the site into multiple languages. Additionally, certain sections were not displaying correctly on the homepage in languages other than French.
Firstly, we addressed the issue with the WooCommerce product images not displaying. We identified that the custom field for the category image was incorrectly set. We recommended setting 'thumbnail_id' to 'Copy' in WPML -> Settings -> Custom Term Meta Translation. The client needed to edit each product category in French and re-save it to automatically copy the image to the translated categories. It was also important to flush the cache memory after completing these steps.
For the sections not displaying correctly, the issue was with an Elementor element that needed registration for translation. We provided guidance on registering the custom Elementor widgets for translation by following the guide at https://wpml.org/documentation/related-projects/wpml-compatibility-test-tools-plugin/registering-custom-elementor-widgets-for-translation/. Additionally, we provided the necessary XML code to be added in WPML -> Settings -> Custom XML Configuration tab:
<wpml-config><elementor-widgets><widget name="woocommerce-products"><fields><field>query_include</field><field>query_include_term_ids</field><field>query_exclude</field><field>query_exclude_ids</field><field>rows</field><field>products_related_products_title_text</field><field>products_upsells_title_text</field><field>products_cross_sells_title_text</field></fields></widget></elementor-widgets></wpml-config>
The client was advised to update the translated versions of the homepage for the changes to take effect.
If this solution does not resolve your issue, or if it seems outdated or irrelevant to your case, we highly recommend checking related known issues at https://wpml.org/known-issues/, verifying the version of the permanent fix, and confirming that you have installed the latest versions of themes and plugins. If further assistance is needed, please open a new support ticket at https://wpml.org/forums/forum/english-support/.
This topic contains 19 replies, has 2 voices.
Last updated by Carlos Rojas 1 year, 1 month ago.
Assisted by: Carlos Rojas.
May 14, 2024 at 8:43 am #15624004
valentinB-22
woo-commerce images are not display after translation
May 14, 2024 at 8:51 am #15624148
valentinB-22
I have translated the site in different languages but the woo-commerce products images and some section images are not displayed. can you please me out
May 14, 2024 at 9:16 am #15624369
Carlos Rojas
WPML Supporter since 03/2017
Thank you for contacting us
1.- I kindly ask you to share a URL where the issue with the images can be seen.
2.- I would like to request temporary access (wp-admin and FTP) to your site to take a better look at the issue. You will find the needed fields for this below the comment area when you log in to leave your next reply. The information you will enter is private which means only you and I can see and have access to it.
Our Debugging Procedures
I will be checking various settings in the backend to see if the issue can be resolved. Although I won't be making changes that affect the live site, it is still good practice to back up the site before providing us access. If we do need to debug the site further, I will duplicate the site and work in a separate, local development environment to avoid affecting the live site.
3.- Please provide the debug information of the site in the section that appears below this ticket.
In this link, you will find the steps to follow: https://wpml.org/faq/provide-debug-information-faster-support/
Please don't paste the debug information within the ticket
Kind regards,
Carlos
May 14, 2024 at 9:48 am #15624581
valentinB-22
Here is the logins:
This website is live, so please be cautious. I've utilized WPML's automatic translation feature to translate the site into five languages. However, some sections and WooCommerce images aren't appearing in languages other than French.Also please check out page and whole site translated or not.
I have spent alot of credits to translate my website but translation is not working
May 14, 2024 at 2:04 pm #15625795
Carlos Rojas
Thank you for sharing the credentials requested.
The cause of the issue was that the custom field for the category image was incorrectly set. I went to WPML -> Settings -> Custom Term Meta Translation -> Set 'thumbnail_id' to 'Copy'.
Now you need to edit each product category in French and re-save it. It will automatically copy the image to the translated categories. -Don't forget to flush the cache memory once you finish-
Important note: Please go to hidden link and translate the first four (4) rows of slugs.
Can you confirm that the issue was solved?
May 15, 2024 at 6:28 am #15627734
valentinB-22
Since this appears to be a WPML-related problem and I've already worked extensively with automatic translation, consuming a significant amount of credits, could you please handle this for us? It's crucial that this issue is resolved promptly. Additionally, kindly ensure that all translations are functioning correctly.
May 15, 2024 at 8:14 am #15628200
Carlos Rojas
The steps I described won't consume any credits and are a configuration issue, not a translation issue. So I kindly ask you to follow the steps I described to solve the problem.
Let me know if you find any issues with the steps described.
May 15, 2024 at 9:50 am #15629008
valentinB-22
I've followed the steps outlined above, but certain sections aren't displaying when I translate the website into different languages, except for French, on the homepage. Could you please investigate this issue and fixed it? hidden link
Also I have try to translate it manually please check this as per above message
May 15, 2024 at 12:17 pm #15630330
Carlos Rojas
Thank you for following the steps described.
To solve the issue of the missing section I had to register the Elementor element by following this guide: https://wpml.org/documentation/related-projects/wpml-compatibility-test-tools-plugin/registering-custom-elementor-widgets-for-translation/
You can find the XML code for registering the element in WPML -> Settings -> Custom XML Configuration tab:
<wpml-config>
  <elementor-widgets>
      <fields>
        <field>rows</field>
      </fields>
    </widget>
</wpml-config>
Then only step that needs to be done is to update the translated versions of the homepage so the changes can take effect. You can manually or automatically translate the homepage.
May 15, 2024 at 1:21 pm #15630624
valentinB-22
I manually translated the page into English, but unfortunately, missing sections are still not display. Could you please review and fix it into all the languages for me?
I have already spent lot of money in automatic translation. Please fixed this issue for me.
May 16, 2024 at 7:33 am #15633245
valentinB-22
Hey Support we are still waiting for your response on the above issue.
Please fixed above issue and provide me the update ASAP
May 16, 2024 at 8:16 am #15633587
Carlos Rojas
In this case the fastest way to solve the issue is by manually editing with Elementor the translated pages and adjust the categories of the products with the correct one depending on the language.
May 16, 2024 at 9:00 am #15633908
valentinB-22
Hey
I've completed all the steps mentioned above, but I'm still unable to translate the missing sections on the homepage. It appears that there may be an issue with the WPML plugin. I've requested assistance previously, but the response time on the ticket has been lengthy. If you're unable to resolve this issue, please inform us. I've already invested a significant amount of money into this plugin and the lack of support is concerning.
May 16, 2024 at 9:14 am #15634034
Carlos Rojas
Hey,
I can see you didn't follow the steps I described. I made the changes in the English version of the home page and attached two screenshots showing what and where to make the changes.
Please take the same steps for the rest of the translated versions of the homepage to solve the problem.
FireShot Capture 258 - Modifier « Home page » avec Elementor - stefanodesign.com.png
FireShot Capture 257 - Modifier « Home page » avec Elementor - stefanodesign.com.png
May 16, 2024 at 9:31 am #15634155
valentinB-22
When i have tried to edit in Elementor i get this message
or if i can edit the way anyhow it will open in french
please provide me screen-shot of steps so that i can do it myself.
