Sales agent dashboard wasn't being translated into English on frontend.
The plugin has a setting in WooCommerce -> Settings -> Sales Agent which sets the agent dashboard page in a configuration (wcb2bsa_dashboard_page). This is a string and is found in Admin strings. It needs to be included in ST and translated as mentioned below:
1. Go to WPML -> String Translation -> Scroll to the bottom of the page and click "Translate texts in admin screens".
2. In "Admin Texts Translation", search for "wcb2bsa_dashboard_page".
3. Add to string translation.
4. Go back to String Translation and search for same field (wcb2bsa_dashboard_page).
5. By default you'll see the English flag with the string and a value, which is the page ID of the "Sales agents dashboard" page in Italian.
6. Change the language of the string to Italian because it is the default language of the site (adjust accordingly).
7. Then go to Pages and switch to English from top admin bar. Then mouse over the page and note the page ID.
8. Then translate the string in ST with the value of English version of "Sales agents dashboard" page ID (noted in #7).
Last updated by Waqas Bin Hasan 1 year, 11 months ago.
Assisted by: Waqas Bin Hasan.
June 20, 2023 at 4:20 pm #13861869
micheleG-6
Hi everybody,
When I log in as an agent from the italian version of the website, the sales dashboard area is fine and in italian.
When I log in as an agent from the english version I only see the italian version of the website and the page "hidden link" is not the one I need.
June 21, 2023 at 11:06 am #13867071
Waqas Bin Hasan
WPML Supporter since 05/2014
Please make sure the translation of this page is 100% complete and there's no gear icon or circular arrows mentioning an in-progress or needs-update kind of statuses.
Also please try the followings:
- Take a full backup of site and database before proceeding.
- Go to WPML -> Settings -> Translate Link Targets and click "Scan now and adjust links" button and see if it helps.
- If it doesn't, please try some troubleshooting options mentioned at https://wpml.org/documentation/support/wpml-troubleshooting-options/
If none of this helps, then repeat the above mentioned with minimal setup, like only with WPML and most required plugins while deactivating all others.
Let me know how it goes.
Regards.
June 21, 2023 at 1:12 pm #13868319
micheleG-6
I tried the first idea on the staging website but nothing.
About the second, can you be a little more specific? Which one do you suggest? I've already tried to delete cash.
Do you want access to the website?
June 21, 2023 at 1:48 pm #13869041
Waqas Bin Hasan
Thank you for trying.
The minimal setup is meant to try with only most required plugins to get to that page like:
- WPML plugins
- WooCommerce
- And related B2B addon(s)
If this doesn't help, yes, allow me admin access to your staging site, with some steps to reproduce and observe the issue.
I've set your next reply as private to share this information safely.
IMPORTANT: If you don't see the section for providing access information, do not write in the message box or the information may appear as public.
June 22, 2023 at 6:16 am #13872723
Waqas Bin Hasan
Sure, I am working on it and 'll get back to you as soon as I find a solution or need more information.
June 22, 2023 at 7:05 am #13872981
Waqas Bin Hasan
I am seeing both Italian and English (sales agent dashboard) pages the same. The one you showed previously is nothing like these.
Can you setup one like shown previously (image and video)? So I can observe the problem properly.
Also write any steps needing to edit/update those pages and translations.
June 22, 2023 at 7:35 am #13873301
micheleG-6
Ciao to replicate the issue, open on a different browser and login as an agent:
1. Go here: hidden link
2. Username: **** PSW: ****
3 You'll notice that hidden link
is different from hidden link
June 22, 2023 at 9:04 am #13874815
Waqas Bin Hasan
Thank you, I am working on it...
June 22, 2023 at 11:12 am #13875669
Waqas Bin Hasan
It is fixed now on the staging site. Let me explain what you need to do to apply this on your live site:
6. Change the language of the string to Italian because it is the default language of the site.
And you should be good to go.
June 22, 2023 at 1:11 pm #13877185
micheleG-6
Great, I made it. Thank you really much. I didn't know about this feature, this is really interesting.
I just have one more question about a filter with Be-Rocket that is not showing in english version: hidden link
June 22, 2023 at 1:32 pm #13877745
Waqas Bin Hasan
Thank you for confirming and glad it worked for you.
Apparently looks like that Be-Rocket isn't on compatibility list (https://wpml.org/plugin/?wpv_view_count=120064&wpv-plugin-functionality=0&wpv_post_search=Be-Rocket&wpv-wpcf-recommendation-flag=&wpv_filter_submit=Search), if that's a plugin, I'll suggest to check with their support.
However, I'll also suggest to open a separate ticket for this, because as per our support policy we can address one issue per ticket, so if others looking for a solution can find it easily.
I am closing this ticket as resolved!
