Supporter timezone: Africa/Cairo (GMT+02:00)
This topic contains 12 replies, has 0 voices.
Last updated by Osama Mersal 3 months, 4 weeks ago.
Assisted by: Osama Mersal.
December 16, 2025 at 6:24 pm #17668921
rafaelF-23
After recent updates, my products (bookable) stopped making the translations correctly.
Now, fields like availability and bookable persons, are not sent over to the translation.
One one hand, i use a template, that before the update, added the translation automatically after saving as draft, and now it doesn't.
On the other hand, even if i add the translation manually, it still doesn't add the bookable persons.
On another note, i also noticed that when i try to use the wpml editor i always get an error that i cannot understand or fix : "Missing markers. Your segment is missing required markers". I get it with simple text strings, no markers...
Attached are screenshots of the issue and of my current settings
December 17, 2025 at 11:44 am #17670770
Osama Mersal
I would need to look closely at your site, so I would need to request temporary access (WP-Admin and FTP)
❌ Please back up your database and website ❌
✙ I need your permission to deactivate and reactivate plugins and themes, and to change site configurations. This is also why the backup is critical.
Osama
December 18, 2025 at 9:08 am #17673688
Osama Mersal
1) I'm afraid I can't add or change the email address because the emails are sent correctly by our system to your account email.
2) Could you please share a screen-recorded video while reproducing the issue to help me understand it better?
3) I don't recommend working on a live site, so I need your permission to install the Duplicator Pro plugin so I can take a local copy and debug the issue without affecting your site.
Osama
December 18, 2025 at 10:57 am #17674130
rafaelF-23
it seems the issues as been fixed, the products are translating correctly again.
Could you than take a look at the other case, at why some of our booking don't generate or link the translations?
Yes you can install the plug in. Thanks
December 18, 2025 at 11:17 am #17674348
rafaelF-23
About the wpml editor, i still have that error: hidden link
December 18, 2025 at 12:47 pm #17674754
Osama Mersal
Could you please check the provided access because I can't see WPML-> Translation Management, Languages, and String Translation pages?
Also, please share an example of the problematic products to check them.
Osama
December 18, 2025 at 2:39 pm #17675099
rafaelF-23
You have admin access and should be able to see all those options. If you can't, maybe i can share a temporary login link if you allow e to send it privately.
In this case i'm no longer talking about products, but bookings.
Case 1: bookings that don't generate a translation
Case 2: bookings that generated a translation but are not linked
December 18, 2025 at 2:52 pm #17675196
Osama Mersal
1) Please check the attached screenshots to see my view of WPML, and when I try to enter the URL manually.
2) Please take a backup of your site and try the following steps:
1- Go to WPML-> Support-> Troubleshooting
2- Run the functions one by one (Kindly check this hidden link">screenshot)
3- Clear the site's cache and check the bookings
❌ Please back up your database before the above steps ❌
3) My following answer might be delayed due to the weekend.
Osama
December 22, 2025 at 10:54 am #17681785
rafaelF-23
Hi, i have done the troubleshooting and the issues remain.
December 22, 2025 at 12:55 pm #17682166
Osama Mersal
Thanks for your update. Could you please check the provided account? Kindly check the screenshot added to my previous reply.
Osama
December 29, 2025 at 11:34 am #17694655
rafaelF-23
Yes i have followed all your instructions, screenshot included, the problem remains.
I also have checked the access i gave you and i have no idea why you don't see all the options, please allow me to send you a different access privately.
December 29, 2025 at 1:34 pm #17694890
Osama Mersal
I've enabled the private reply for you to share the access details.
Osama
December 30, 2025 at 10:34 am #17696467
Osama Mersal
Thanks for the access details. I checked your settings against the default WooCommerce Bookings settings, and they appear correct.
Please log in to this hidden link">sandbox site and install the WooCommerce Bookings plugin. After that, please try to replicate the issue. If the issue is reproducible, please let me know so I can consult our 2nd-tier support team.
If the issue can't be replicated, I'll take a local copy of your site and try to isolate it.
Osama
The topic ‘[Closed] WooCommerce bookable product translation issue’ is closed to new replies.
