The client needs to translate products in WooCommerce using WPML but is unsure how to proceed.
We recommend translating products in WooCommerce by following these steps:
1. You can translate products automatically as described in our documentation here: Translating Products Automatically.
2. Alternatively, you can send products to be translated by your own team of translators or a professional translation service. Details on how to assign translations can be found here: Assigning the Translations to a Translator.
3. You can also open any product directly and opt for translation.
If this solution does not apply to your situation, or if it seems outdated, we highly recommend checking related known issues at https://wpml.org/known-issues/, verifying the version of the permanent fix, and confirming that you have installed the latest versions of themes and plugins. If further assistance is needed, please open a new support ticket at WPML support forum.
Last updated by Marcel 1 year, 10 months ago.
Assisted by: Marcel.
June 4, 2024 at 11:38 am #15701821
dominikM-32
I need 1 solution. I must translate products.
No specific issue or error message mentioned.
How do I translate products in WooCommerce using WPML?
June 4, 2024 at 12:34 pm #15702018
Bruno Kos
Let us know if you have any questions.
June 5, 2024 at 7:35 am #15705319
dominikM-32
Hi Bruno!
Good news.
It worked. It's not easy, but there is a good option if you know basic Excel.
Translating already uploaded products can be done in two ways. Using the standard importer and using translation via WPML in the Translation Management tab. Today I don't have time to describe the entire process, but remind me by e-mail and I will let you know everything and how. Of course, there is automatic translation, which works well for small amounts of information and I don't know if it will be my most important method.
Let me know. Works without WP All import.
Regards, Adam.
adam@stocklots.tv / zetdee@gmail.com
June 5, 2024 at 2:03 pm #15707353
Marcel
Hi Adam,
I'm Marcel, and I'll be handling your ticket from now on.
Thank you for the information. Just a note, we can only communicate through this support forum. Whenever you have time, feel free to post your solution here for others.
Thanks a lot! 🙂
Marcel
