You are trying to correct the English product URL in WooCommerce which incorrectly contains a 'K' instead of a 'C'.
We recommend you go to WPML > Settings > Post Type Translation and edit the slug for the post type "Products". If the slug is already translated, please edit the fields and save the slug translation again. For detailed guidance, visit Translating Page Slugs documentation.
Afterwards, please resave the permalinks in WordPress at Settings > Permalinks.
If this solution does not resolve your issue, the problem might be outdated or not applicable to your specific case. We highly recommend checking related known issues at https://wpml.org/known-issues/, verifying the version of the permanent fix, and confirming that you have installed the latest versions of themes and plugins. If the issue persists, please open a new support ticket at WPML support forum.
Last updated by kristiyanI 3 days, 13 hours ago.
June 25, 2025 at 11:03 pm #17170982
kristiyanI
I am trying to fix the WooCommerce product URLs on my site hidden link. I have set up the correct slugs under WooCommerce -> WooCommerce Multilingual & Multicurrency -> URL slugs, and the general permalinks are also correct.
The English version of the product URL contains a 'K' instead of a 'C'.
How can I correct the English product URL to use 'C' instead of 'K'?
June 26, 2025 at 2:39 am #17171142
To translate this slug, please go to WPML > Settings > Post Type Translation and edit the slug for the post type "Products". If the slug is already translated, please edit the fields and save the slug translation again.
Guide:
https://wpml.org/documentation/getting-started-guide/translating-page-slugs/
Also, after that, please resave the permalinks in WordPress at Settings > Permalinks.
If this will not solve the issue, please let me know.
June 26, 2025 at 12:19 pm #17173412
kristiyanI
Following all steps from the guide and resaving the permalinks settings a few more times solved the issue. Thank you!
