Last updated by Dražen 1 year, 2 months ago.
January 30, 2025 at 8:28 pm #16653404
SandroL
I have rebuilt a site with WooCommerce and WPML and need to transfer all product data from the current site to the new one using WP All Export Pro. The source site has already translated all products with WPML.
No specific issue or error message mentioned.
Do you have experience with exporting and importing data using WP All Export Pro and WP All Export for WooCommerce?
Will all WPML related information for a product be exported and imported?
Do I still need the WPML All Import plugin?
Is there something else I need to consider for this task?
January 31, 2025 at 8:57 am #16654424
Dražen
Thanks for contacting us.
Yes, that is possible, just make sure you have exported the data correctly. You can follow the next guide:
- https://wpml.org/compatibility/2016/08/export-multilingual-websites-using-wp-all-export-and-wpml/
Or
- https://wpml.org/documentation/plugins-compatibility/export-multilingual-websites-using-wp-all-export-wpml/
Note they require different addon plugins.
Then just import them regularly and set WPMLtranslationgroup as a unique identifier field and correct import language.
- https://wpml.org/documentation/related-projects/legacy-wpml-all-import/importing-multiple-languages-with-wp-all-import-and-wpml/
Note you need to create/import taxonomies before import of products.
Hope this helps.
Drazen
The topic ‘[Closed] WooCommerce Products with WPML Data Transfer’ is closed to new replies.
