Last updated by Bigul 11 months, 2 weeks ago.
Assisted by: Bigul.
May 15, 2025 at 10:02 am #17036068
tornikeS
I am experiencing a slow query problem with the WPML and WPML String Translation plugins on a site under development. The issue causes the database to overload to 100%. I have tested various solutions, including increasing server specifications, changing to the default theme, turning off WPML, cleaning the wp_icl_strings table, and disabling WP Rocket, but none have resolved the issue. The problem started about a week ago, and WPML seems to be the main cause. I have attached the queries that are consistently running and overloading the database. The website in question is superkilometerfilter.com. Here is an example of the queries: 2025-05-14T10:14:01.983111Z 25080 Query UPDATE `wp_icl_string_translations` SET `status` = '3' WHERE `string_id` = '109'.
The database is overloaded to 100% due to WPML and WPML String Translation plugins, causing server errors.
What should we do to resolve the database overload issue caused by WPML?
Why are WPML and WPML String Translation plugins overloading the database?
How can we optimize WPML to prevent it from running queries that overload the database?
May 15, 2025 at 3:07 pm #17037731
Bigul
Please let us know if this is the same as the following ticket. This will help us avoid duplicate tickets and assist you more efficiently. Thank you for your kind understanding.
https://wpml.org/forums/topic/wpml-and-wpml-string-translation-database-slow-query-problem/
Bigul
The topic ‘[Closed] Wpml and WPML String Translation database slow query problem’ is closed to new replies.
