If you're trying to see the WPML plugin in the Plugins page but can't find it after installing WPML string translation, it might be due to another plugin restricting visibility.
We found that the 'Admin Menu Editor Pro' plugin was preventing the WPML plugins from appearing on the Plugins page. We recommend temporarily deactivating 'Admin Menu Editor Pro' to test if this resolves the issue. If you need this plugin, you might need to configure it to allow WPML plugins to show up. If this solution does not apply to your case, or if it seems outdated, please check related known issues at https://wpml.org/known-issues/, verify the version of the permanent fix, and confirm that you have installed the latest versions of themes and plugins. If you still need assistance, we highly recommend opening a new support ticket at WPML support forum.
Last updated by Mateus Getulio 1 year ago.
Assisted by: Mateus Getulio.
July 10, 2024 at 8:16 pm #15930093
pauliusG-3
Trying to see the WPML plugin in the Plugins page in case I need to disable it or enable it. I've installed the WPML string translation on top of the existing plugin. It allowed me to update the plugin.
The WPML string translation is still not visible on the Plugins page (hidden link).
Why is the WPML string translation not visible on the Plugins page?
How can I make the WPML string translation visible on the Plugins page?
July 11, 2024 at 11:29 am #15934658
Mateus Getulio
Hello there,
It is possible that during the install something went wrong and it didn't fully install it. Are you able to see the menu WPML -> String Translation?
Also, can you please check if it is listed as installed following the steps:
- Inside your wp-admin please go to Plugins -> Add New.
- Then click on the "Commercial" tab and click on the "Check for updates" button in the WPML section
- After that please check if the String Translation appears as installed or available for download
If it is already listed as installed, I would like to request temporary access (wp-admin and FTP) to your site to take better look at the issue. You will find the needed fields for this below the comment area when you log in to leave your next reply. The information you will enter is private which means only you and I can see and have access to it.
Our Debugging Procedures
Privacy and Security Policy
**IMPORTANT**
Please, let me know if you need any additional details. Have a nice day.
July 11, 2024 at 8:41 pm #15937711
Mateus Getulio
Hello Paulius,
Thank you for sharing the access.
I checked it and it seems like there's a plugin meant to limit the wp-admin dashboard that was preventing the WPML plugins from showing up in the list: Admin Menu Editor Pro.
I temporarily left it deactivated for you to test it, because when I enable this plugin, the plugin itself 'Admin Menu Editor Pro' doesn't show up again and you need to rename its folder in wp-content/plugins in order to forceful disable it.
If this plugins is required, there might be a way of configuring it to let WPML plugins show up in the list, please check it.
Thank you,
Mateus
July 11, 2024 at 9:21 pm #15937812
pauliusG-3
thank you! The issue has been resolved, appreciate it.
