You are experiencing issues with WooCommerce product images not syncing across different language versions on your site. After changing a product image in the main language (Polish), other languages display incorrect images. This problem began following a major WPML update.
First, edit a product in the original language and ensure that the checkboxes for duplicating the featured image and attachments in the Language block are checked. Save these changes and update the translation. If the problem persists, navigate to WPML -> Settings -> Media translation section. Here, select the three options in the second sub-section and click 'Start'. Wait for the process to complete and verify if the images now appear correctly in all languages. It's crucial to create a full site backup before performing these steps.
If you have previously used automatic translation, re-sending the products for translation will not incur additional costs as the translations are stored in the Translation Memory. You can test this with a few products first to ensure the issue is resolved before proceeding with the rest.
Please note that we do not provide custom scripts for syncing all fields of products, taxonomies, and metadata as this falls outside our support scope. We recommend following the outlined steps and contacting us if further assistance is needed.
If this solution does not resolve your issue, or if it seems outdated or irrelevant to your case, we highly recommend checking related known issues at https://wpml.org/known-issues/, verifying the version of the permanent fix, and confirming that you have installed the latest versions of themes and plugins. If problems persist, please open a new support ticket at WPML support forum.
Last updated by 7 months, 1 week ago.
Assisted by: Carlos Rojas.
