Last updated by Mihai Apetrei 1 year, 10 months ago.
Assisted by: Mihai Apetrei.
September 12, 2023 at 2:08 pm #14384403
Deysi Merino
I'm trying to install the plugins Multilingual CMS and String Translation, but apparently, it fails under the error "Could not copy file. (sitepress-multilingual-cms/locale/po/sitepress-he_IL.po)".
I was able to install WPForms Multilingual, but not those, so I don't know exactly what is causing that problem.
Also, since I can't install it, I can't provide my debug info.
September 13, 2023 at 8:57 pm #14392567
Mihai Apetrei
WPML Supporter since 03/2018
Hi there.
This could be caused by multiple reasons including server settings.
Can you please try the following steps and see if that works fine?
1. Create a full website backup
2. Disable and delete WPML + the WPML String Translation add-on
3. Download them manually straight from our site here: https://wpml.org/account/downloads/ (click the button below so that you can manually download the zip file)
4. Then go to Plugins > Add new > Upload > and upload the zip file and see if you are able to properly install the latest WPML version. Then, install the "String Translation" add-on.
5. If everything works fine, then go to Plugins > Add new > Commercial > and try to register WPML again in case it shows up as UNREGISTERED
Please let me know how that goes.
Mihai Apetrei
September 13, 2023 at 9:17 pm #14392621
Deysi Merino
Thank you so much for your help, but my issue is resolved.
Since I don't manage the hosting, they told me the space was the issue.
