Last updated by Christopher Amirian 1 year, 10 months ago.
September 8, 2023 at 9:02 am #14364783
efthimiosF
When I try to import products with wpallimport, I am getting the following error and the whole import proccess is stuck.
AH01071: Got error 'PHP message: PHP Notice: Trying to get property 'status_id' of non-object in /var/www/vhosts/b2b.catherinebijoux.com/httpdocs/wp-content/plugins/sitepress-multilingual-cms/classes/post-translation/class-wpml-post-status.php on line 163PHP message: PHP Notice: Trying to get property 'transid' of non-object in /var/www/vhosts/b2b.catherinebijoux.com/httpdocs/wp-content/plugins/sitepress-multilingual-cms/classes/post-translation/class-wpml-post-status.php on line 173PHP message: WordPress database error Column 'translation_id' cannot be null for query INSERT INTO `wp_icl_translation_status` (`status`, `translation_id`) VALUES ('9', NULL) made by require_once('wp-config.php'), require_once('wp-settings.php'), do_action('wp_loaded'), WP_Hook->do_action, WP_Hook->apply_filters, pmxi_wp_loaded_99, Wpai\\Scheduling\\Import->process, PMXI_Import_Record->execute, PMXI_Import_Record->process, wp_update_post, wp_insert_post, do_action('save_post'), WP_Hook->do_action, WP_Hook->apply_filters, WPML_Media_Attachments_Duplication->save_post_actions, WPML_Media_Attachments_Duplication->sync_attachments, WPML_Media_Attachments_Duplication->duplicate_post_attachments, WPML_Media_Attachments_Duplication->create_duplicate_attachment, WPML_Model_Attachments->duplicate_attachment, WPML_Model_Attachments->add_language_information_to_attachment, WPML_Post_Status->set_statusPHP message: PHP Notice: Trying to get property 'status_id' of non-object in /var/www/vhosts/b2b.catherinebijoux.com/httpdocs/wp-content/plugins/sitepress-multilingual-cms/classes/post-translation/class-wpml-post-status.php on line 163PHP message: PHP Notice: Trying to get property 'transid' of non-object in /var/www/vhosts/b2b.catherinebijoux.com/httpdocs/wp-content/plugins/sitepress-multilingual-cms/classes/post-translation/class-wpml-post-status.php on line 173PHP message: WordPress database error Column 'translation_id' cannot be null for query INSERT INTO `wp_icl_translation_status` (`status`, `translation_id`) VALUES ('9', NULL) made by require_once('wp-config.php'), require_once('wp-settings.php'), do_action('wp_loaded'), WP_Hook->do_action, WP_Hook->apply_filters, pmxi_wp_loaded_99, Wpai\\Scheduling\\Import->process, PMXI_Import_Record->execute, PMXI_Import_Record->process, PMWI_Import_Record->import, wpai_woocommerce_add_on\\XmlImportWooCommerceProduct->import, wpai_woocommerce_add_on\\importer\\ProductsImporter->import, wpai_woocommerce_add_on\\importer\\products\\ImportVariableProduct->import, wpai_woocommerce_add_on\\importer\\products\\ImportVariableProduct->importParentProduct, wpai_woocommerce_add_on\\importer\\products\\ImportVariableProduct->initParentProduct, wp_update_post, wp_insert_post, do_action('save_post'), WP_Hook->do_action, WP_Hook->apply_filters, WPML_Media_Attachments_Duplication->save_post_actions, WPML_Media_Attachments_Duplication->sync_attachme...PHP message: PHP Notice: Trying to get property 'status_id' of non-object in /var/www/vhosts/b2b.catherinebijoux.com/httpdocs/wp-content/plugins/sitepress-multilingual-cms/classes/post-translation/class-wpml-post-status.php on line 163PHP message: PHP Notice: Trying to get property 'transid' of non-object in /var/www/vhosts/b2b.catherinebijoux.com/httpdocs/wp-content/plugins/sitepress-multilingual-cms/classes/post-translation/class-wpml-post-status.php on line 173PHP message: WordPress database error Column 'translation_id' cannot be null for query INSERT INTO `wp_icl_translation_status` (`status`, `translation_id`) VALUES ('9', NULL) made by require_once('wp-config.php'), require_once('wp-settings.php'), do_action('wp_loaded'), WP_Hook->do_action, WP_Hook->apply_filters, pmxi_wp_loaded_99, Wpai\\Scheduling\\Import->process, PMXI_Import_Record->execute, PMXI_Import_Record->process, PMWI_Import_Record->import, wpai_woocommerce_add_on\\XmlImportWooCommerceProduct->import, wpai_woocommerce_add_on\\importer\\ProductsImporter->import, wpai_woocommerce_add_on\\importer\\products\\ImportVariableProduct->import, wpai_woocommerce_add_on\\importer\\products\\ImportVariableProduct->importVariations, wpai_woocommerce_add_on\\importer\\products\\ImportProduct->save, WC_Product->save, WC_Data_Store->update, WC_Product_Variation_Data_Store_CPT->update, wp_update_post, wp_insert_post, do_action('save_post'), WP_Hook->do_action, WP_Hook->apply_filters, WPML_Media_Attachments_Duplication->save_p...PHP message: PHP Fatal error: Allowed memory size of 268435456 bytes exhausted (tried to allocate 20480 bytes) in /var/www/vhosts/b2b.catherinebijoux.com/httpdocs/wp-includes/class-wpdb.php on line 2425'
I have same error like this:
https://wpml.org/forums/topic/error-occured-while-importing-product-using-wp-all-import/
September 11, 2023 at 6:28 am #14372889
Christopher Amirian
WPML Supporter since 07/2020
I searched our forum and internal reports and the only instance I saw was a case in which the problem was caused by a custom code added in the Child Theme of the customer.
So for now I'd appreciate it if you could test the import process in a copy/staging website as a test with the criteria below:
- Change the website theme to 2020 or a default theme.
- Deactivate all plugins except, WPML, Woocommerce, WP All Import (and their necessary add-on plugins to make sure everything works)
- Perform the process again.
- See if the result is ok.
- If yes, then please enable the Child theme and test, if it is ok then plugins one by one, to find the culprit.
September 11, 2023 at 7:21 am #14373031
efthimiosF
I have already check that but same error. If I change the php version to 8.0.3, I get this error:
AH01071: Got error 'PHP message: PHP Fatal error: Uncaught Exception: No trid for product variation in secondary language, imposssible to set _wcml_duplicate_of_variation in /var/www/vhosts/b2b.catherinebijoux.com/httpdocs/wp-content/plugins/wpml-all-import/wpml-all-import.php:325\nStack trace:\n#0 /var/www/vhosts/b2b.catherinebijoux.com/httpdocs/wp-includes/class-wp-hook.php(312): WPAI_WPML->saved_post()\n#1 /var/www/vhosts/b2b.catherinebijoux.com/httpdocs/wp-includes/class-wp-hook.php(334): WP_Hook->apply_filters()\n#2 /var/www/vhosts/b2b.catherinebijoux.com/httpdocs/wp-includes/plugin.php(517): WP_Hook->do_action()\n#3 /var/www/vhosts/b2b.catherinebijoux.com/httpdocs/wp-content/plugins/wp-all-import-pro/models/import/record.php(4725): do_action()\n#4 /var/www/vhosts/b2b.catherinebijoux.com/httpdocs/wp-content/plugins/wp-all-import-pro/controllers/admin/import.php(2799): PMXI_Import_Record->process()\n#5 /var/www/vhosts/b2b.catherinebijoux.com/httpdocs/wp-content/plugins/wp-all-import-pro/wp-all-import-pro.php(763): PMXI_Admin_I...', referer: hidden link
Could you help us?
Do you need admin credentials ?
Thank you
September 11, 2023 at 11:14 am #14375645
Christopher Amirian
The "_wcml_duplicate_of_variation" portion of the error gave me an idea, please make sure that the attributes of the products are already translated from Woocommerce > Woocommerce > Multilingual & Multicurrency > Attributes (tab).
After that, please do the import but make sure you set the option mentioned below correctly:
https://wpml.org/documentation/related-projects/wpml-all-import-plugin-website-import-with-wpml/#importing-content-in-one-language
In Step 3, expand the Configure Advanced Settings section and disable the option to increase the speed of the import process. You can do this by unchecking the box next to Increase speed by disabling do_action calls in wp_insert_post during import.
See if it fixes the issue.
September 15, 2023 at 12:53 pm #14403335
efthimiosF
I am having the following error in the end of wpallimport process:
AH01071: Got error 'PHP message: PHP Fatal error: Uncaught TypeError: call_user_func_array(): Argument #1 ($callback) must be a valid callback, class WCML_Synchronize_Product_Data does not have a method "delete_empty_post_meta_for_translations" in /var/www/vhosts/b2b.catherinebijoux.com/httpdocs/wp-includes/class-wp-hook.php:312\nStack trace:\n#0 /var/www/vhosts/b2b.catherinebijoux.com/httpdocs/wp-includes/class-wp-hook.php(334): WP_Hook->apply_filters()\n#1 /var/www/vhosts/b2b.catherinebijoux.com/httpdocs/wp-includes/plugin.php(517): WP_Hook->do_action()\n#2 /var/www/vhosts/b2b.catherinebijoux.com/httpdocs/wp-includes/meta.php(528): do_action()\n#3 /var/www/vhosts/b2b.catherinebijoux.com/httpdocs/wp-includes/post.php(2496): delete_metadata()\n#4 /var/www/vhosts/b2b.catherinebijoux.com/httpdocs/wp-content/plugins/woocommerce/includes/data-stores/class-wc-product-variable-data-store-cpt.php(602): delete_post_meta()\n#5 /var/www/vhosts/b2b.catherinebijoux.com/httpdocs/wp-content/plugins/woocommerce/includes/class-wc-data-store.php(2...'
could you help us?
September 15, 2023 at 12:54 pm #14403343
efthimiosF
Is something related to wpml or to wp all import?
September 17, 2023 at 11:54 am #14408135
Christopher Amirian
The second message you shared seems to be like the issue mentioned below:
https://wpml.org/errata/wpml-all-import-and-php-8-fatal-error-uncaught-typeerror-call_user_func_array-when-importing-products/
Would you please use the workaround there and see if the message goes away?
The topic ‘[Closed] Wpml + Wpallimport Problem’ is closed to new replies.
