The client reported an issue where the main shop-page in English displayed prices in euros instead of dollars when viewed from the US, and the single product page showed prices only in euros. This discrepancy occurred despite using WooCommerce Multilingual & Multicurrency with geolocation-based currency settings.
We initially suggested checking if the issue was related to caching, either via the website cache or the browser cache. After further investigation and testing with a VPN set to the US, it appeared that clearing the cache resolved the issue. We recommended the client to continue monitoring the situation and to clear the cache regularly to prevent similar issues. Additionally, we advised setting up the site in a minimal environment to check for any conflicts with themes or plugins if the problem reoccurred. This involves switching to a default WordPress theme and deactivating all plugins except for WPML, its add-ons, and WooCommerce. If the issue persists, the client should activate plugins one by one to identify the problematic plugin.
This topic contains 14 replies, has 1 voice.
Last updated by thomasD-100 2 days, 9 hours ago.
Assisted by: Itamar.
August 11, 2025 at 7:56 am #17308267
thomasD-100
For now I think I am fine. I will check in the next days/weeks if everything works correctly. Otherwise, I'll get back to you.
Thanks a lot for your support!
