You need to translate elements like headers and footers created with GeneratePress and Blocks.
We recommend following our detailed guide on how to translate these elements using WPML. You can find the guide here: Translating GeneratePress Theme Using WPML.
If this solution does not apply to your case, or if it seems outdated, please check the related known issues at https://wpml.org/known-issues/, verify the version of the permanent fix, and confirm that you have installed the latest versions of themes and plugins. We highly recommend opening a new support ticket if you need further assistance. You can do so at WPML support forum.
This topic is split from https://wpml.org/forums/topic/page-not-translated-correctly/
Last updated by 1 year, 9 months ago.
Assisted by: Andrey.
