Last updated by barjD 1 year, 10 months ago.
August 25, 2023 at 10:46 pm #14293947
barjD
I am trying to deactivate all plugins on my site to troubleshoot something.
Every time I do so, I get a "Critical error" message on my site and nothing works:
Fatal error: Uncaught Error: Undefined constant "ICL_LANGUAGE_CODE" in /nas/content/live/dhahanstage/wp-content/themes/infinity-pro/functions.php:66 Stack trace: #0 /nas/content/live/dhahanstage/wp-includes/class-wp-hook.php(312): wpml_lang_body_class(Array) #1 /nas/content/live/dhahanstage/wp-includes/plugin.php(205): WP_Hook->apply_filters(Array, Array) #2 /nas/content/live/dhahanstage/wp-includes/post-template.php(862): apply_filters('body_class', Array, Array) #3 /nas/content/live/dhahanstage/wp-content/themes/genesis/lib/functions/markup.php(319): get_body_class() #4 /nas/content/live/dhahanstage/wp-includes/class-wp-hook.php(312): genesis_attributes_body(Array) #5 /nas/content/live/dhahanstage/wp-includes/plugin.php(205): WP_Hook->apply_filters(Array, Array) #6 /nas/content/live/dhahanstage/wp-content/themes/genesis/lib/functions/markup.php(214): apply_filters('genesis_attr_bo...', Array, 'body', Array) #7 /nas/content/live/dhahanstage/wp-content/themes/genesis/lib/functions/markup.php(232): genesis_parse_attr('body', Array, Array) #8 /nas/content/live/dhahanstage/wp-content/themes/genesis/lib/functions/markup.php(108): genesis_attr('body', Array, Array) #9 /nas/content/live/dhahanstage/wp-content/themes/genesis/header.php(41): genesis_markup(Array) #10 /nas/content/live/dhahanstage/wp-includes/template.php(785): require_once('/nas/content/li...') #11 /nas/content/live/dhahanstage/wp-includes/template.php(720): load_template('/nas/content/li...', true, Array) #12 /nas/content/live/dhahanstage/wp-includes/general-template.php(48): locate_template(Array, true, true, Array) #13 /nas/content/live/dhahanstage/wp-content/themes/genesis/lib/framework.php(24): get_header() #14 /nas/content/live/dhahanstage/wp-content/themes/genesis/single.php(15): genesis() #15 /nas/content/live/dhahanstage/wp-includes/template-loader.php(106): include('/nas/content/li...') #16 /nas/content/live/dhahanstage/wp-blog-header.php(19): require_once('/nas/content/li...') #17 /nas/content/live/dhahanstage/index.php(17): require('/nas/content/li...') #18 {main} thrown in /nas/content/live/dhahanstage/wp-content/themes/infinity-pro/functions.php on line 66
There has been a critical error on this website.
Please see here: https://wpml.org/forums/topic/rtl-blank-space-when-screen-size-changes-or-using-inspect-element-in-chrome/
You can input
// add lang code in body class
function wpml_lang_body_class($classes) {
$classes[] = ICL_LANGUAGE_CODE;
return $classes;
add_filter('body_class','wpml_lang_body_class');
Into a child theme's functions.php file and then deactivate all plugins
I am wondering if someone can help with a corrected solution to include language codes as body classes while not having the whole site go down if plugins are disabled?
Thank you
August 27, 2023 at 1:22 pm #14296399
Christopher Amirian
WPML Supporter since 07/2020
The "ICL_LANGUAGE_CODE" is deprecated and it is better to use the method below:
https://wpml.org/faq/how-to-get-current-language-with-wpml/
Just so you know, WPML adds language code by default to the HTML tag's lang attribute.
So if for example, you want to select a page in Panjabi to use in CSS or Javascript you can add:
html[lang="pa"]
Then the rest of selectors. For example a class called container only in Panjabi will be selected this wayL
html[lang="pa"] .container {
...rest of the CSS code
August 28, 2023 at 7:38 pm #14303129
barjD
Hello, thank you.
Can you please clarify, because if I take out:
return $classes;
Then the css classes I have defined for .pa and .pa_sh don't work.
Your solution also didn't work for me 🙁
As an example of how I was using the CSS, when I take that code out of functions.php, and I use in style.css:
html[lang="pa"] .site-title a {
background: url(hidden link) no-repeat!important;
bottom:1rem;
It also doesn't work (I cleared website cache and checked incognito window). Do you have an example of it working in this type of context?
However, can you explain more about modifying or replacing the ICL_LANGUAGE_CODE which is now depreciated?
Would I change the code above to:
$classes[] = wpml_current_language;
return $classes;
the code above gives me an error... but to be honest I'm confused how to use the solution on the page you gave me.
I am open to the best way to do this, but I am not sure how to solve this, since the html[lang="pa"] solution is not working...
Thank you for your help
August 29, 2023 at 12:21 am #14303441
barjD
I figured out the language code is supposed to be pa-in for Punjabi in Gurmukhi, not just pa.
However, it would still help to have a body class as a fallback, just in case.
If you can still help with that it would be very appreciated.
Thank you
August 30, 2023 at 11:37 am #14312915
Christopher Amirian
You can use the hook mentioned here:
https://wpml.org/wpml-hook/wpml_current_language/
A sample code that you can work your ways around can be this:
function my_custom_body_class($classes) {
    $lang = apply_filters('wpml_current_language', NULL);
    if ($lang) {
        $classes[] = 'lang-' . $lang;  // This will add a class like "lang-en" for English, "lang-fr" for French, etc.
    return $classes;
add_filter('body_class', 'my_custom_body_class');
Please consider that we are not able to give customization code as it is outside of our support scope. If you need additional help with the code you can ask for help from a developer:
https://wpml.org/contractors/
September 3, 2023 at 11:44 pm #14333027
barjD
Thank you very much
September 3, 2023 at 11:45 pm #14333033
barjD
Thank you for your helpfulness
