Home » WPML Documentation » Related Projects » Advanced Custom Fields (ACF) Multilingual – Translate All Fields with WPML
Advanced Custom Fields (ACF) Multilingual – Translate Fields with WPML
ACFML is a WPML add-on that allows building multilingual sites with ACF and ACF Pro.
Trusted by 70,000+ developers
Key Features
Translate any field available in ACF and ACF Pro
Use AI translation or translate by yourself
Show the same or different fields across languages
Required Plugins
To translate your website with ACFML, install and activate the following plugins:
How to Translate with ACFML
The steps that you need to take to translate the ACF fields depend on the setup of the field group. When you set-up a new field group, ACFML will offer you three translation options.
Option 1: Same fields across languages
This option is the typical setting most ACF websites use. It lets you translate your custom fields values while maintaining their structure across languages.
For example, think about the “our team” page on your website. Your team is the same, no matter the language of the page. Since you’re showing the same information (the people on your team and their details), you should use “same fields across languages” for the fields in this group.
You’ll enter the information about your team once, in the site’s default language. Then, you’ll translate these details to the rest of the site’s languages.
Team page in English
Team page in Spanish
To display the same fields across languages:
  1. Go to ACF Field Groups and edit your Field Group.
  2. Under Multilingual Setup, select the Same fields across languages option.
Selecting same fields across languages
  1. Finally, go to WPML Translation dashboard and send the content with your custom fields for translation.
If you can’t find your content in Translation Dashboard, go to WPML Settings, scroll down to Post Type Translation, and verify your content is set to Translatable.
Option 2: Different fields across languages
This option lets you show translated fields with different values in each language. It’s useful when you want to show localized versions of similar content.
Think about a company that organizes events and offers different events for audiences in different languages. The “events” page will need to show different content (events) for each language.
Events in English
Events in English
Events in Spanish
Events in Spanish
To display different fields across languages:
  2. Under Multilingual Setup, select the Different fields across languages option.
Selecting different fields across languages
  1. Next, locate the content with your custom fields (e.g., page, post) and click Edit.
  2. On the right sidebar, click the Plus icon for the language you want to show different fields for.
Plus icons in under Translate this Document
Plus icons on right sidebar
  1. A blank draft will open with empty custom fields. Enter your translated, different values for each field and click Publish.
Empty custom fields
Empty custom fields
Option 3: Expert Mode (Advanced)
Expert Mode lets you manually control the translation preferences for each custom field. This option is useful when you want a combination of same and different fields across languages, and need independent translation control per field.
For instance, in the event example below, we have a mix of fields with different translation preferences; the title and description are translated, while the price, date, and address are copied.
Event in English
Event in English
Event in Spanish
Event in Spanish
Expert mode is available alongside the other ACFML options, when choosing a Field Group translation method.
Translate Field Labels
ACF field labels are the names that identify each custom field in the WordPress editor. On the front-end, field labels are usually displayed on forms to help identify different fields.
Field label in backend
Field label on front-end
To translate ACF field labels:
  1. Go to WPML Translation Dashboard.
  2. Open the ACF Field Group section and send your Field Group Labels item for translation.
Translate ACF Field Choices
ACF field choices are custom fields with multiple choices, such as radio buttons, dropdown selects, and checkboxes. These fields are typically used in forms, and need to be translated separately.
ACF choices in a contact form
To translate ACF field choices:
  2. Open the ACF Field Group section and send the item with your ACF choices for translation.
Get Started with ACFML
Start building a multilingual website with custom fields.
Frequently Asked Questions
Updated
November 28, 2025
