Last updated by Osama Mersal 1 year, 6 months ago.
Assisted by: Osama Mersal.
August 22, 2023 at 2:35 pm #14272265 | |
annikaN-2 |
Tell us what you are trying to do? Translate listings Is there any documentation that you are following? There is no good documentation on this Is there a similar example that we can see? The Swedish listing example (Swedish is the main language) hidden link What is the link to your site? This is just a test page on a subdomain hidden link |
August 22, 2023 at 3:32 pm #14272619 | |
annikaN-2 |
I also saw that the Distans over the map is not picked up for translation |
August 23, 2023 at 8:24 am #14275753 | |
Osama Mersal Supporter
Languages: English (English ) Arabic (العربية ) Timezone: Africa/Cairo (GMT+02:00) |
Hi, Thanks for contacting WPML forums support. I'll be glad to help you today. Please try to translate the strings using WPML-> String Translation. If you didn't find the strings, kindly try the following steps: 1- Go to WPML-> Theme and plugins localization, select your theme/plugin, and scan Kindly check our guide to know more about translating texts in the admin texts screen. (https://wpml.org/documentation/getting-started-guide/string-translation/finding-strings-that-dont-appear-on-the-string-translation-page/) Best regards, |
August 23, 2023 at 10:58 am #14277741 | |
annikaN-2 |
Hi again, Thanks, |
August 23, 2023 at 11:05 am #14277801 | |
Hi Annika, Please login to this sandbox site and upload the Directorist plugin. (hidden link) After that, please create a listing and translate it to replicate the issue. If the issue is replicable, please let me know the steps to reproduce the issue. Thanks for your cooperation Best regards, |
August 23, 2023 at 11:23 am #14277973 | |
annikaN-2 |
Hi again, Thanks, |
August 23, 2023 at 11:40 am #14278089 | |
Hi Annika, It's better to replicate the issue on the fresh installation to avoid any plugin conflict, but I can check the issue on your site first to see if it has a quick fix. I would need to request temporary access (WP-Admin and FTP) Your answer will be private, meaning only you and I can access it. ❌ Please backup your database and website ❌ ✙ I would need your permission to de-activate and re-activate the Plugins and the Theme and change configurations on the site. This is also a reason the backup is critical. ✙ I also need your permission to take a local copy of your site to debug the issue without affecting your live site. Best regards, |
August 23, 2023 at 12:42 pm #14278501 | |
Hi Annika, Thanks for the access details. I set the following custom fields to be translatable. After that, the mentioned strings appeared correctly in the translation editor. I tested it on the following listing. (hidden link) Please update another listing in the default language and translate it to check if the issue is fixed. If the issue is fixed, please check the following steps to fix it on your live site: 1- Go to WPML-> Settings-> Custom Fields translation section Best regards, |
August 23, 2023 at 1:32 pm #14278657 | |
annikaN-2 |
Thank you ever so much, great everything seems to work fine and this was what I had in mind but couldn't find it. |
