Hi
I need help with posts showing in every language even without being translated
I checked the support questions and tryed this method but is not working.
2. Have the posts "appear as translated"
You could set the multilingual options of the post types to be "Translatable - use translation if available or fallback to default language" here: WPML > Settings > POst type translation
This may meet your needs depending on how the archive page is written.
Hello There,
Thanks for contacting WPML Support. I will try my best to assist you in this matter.
I understood that you want the default post to appear in other languages. From the Debug info you've shared, I can see that the translation preference for the post is set correctly and I also have found that the posts in the default language are also appearing in other languages as per your expectation. Please check this video(hidden link) for a better understanding.
Can you please share on which page specifically you're having the issue? So that I can check and let you know an update.
