You are trying to ensure that your French homepage is fully translated. Previously, the entire page was translated, but now some parts have reverted back to English, even though they appear to be translated in the string translations.
1. Check if the issue occurred after updating to WordPress 6.7. If so, consider reading the following errata: Missing translations on front-end.
2. As a possible workaround, you might want to downgrade WordPress to its prior version on your staging site to see if this resolves the issue.
3. Ensure that your browser settings do not block important language cookies used by WPML, as some browsers like Thor might cause issues. Use a standard browser like Google Chrome to check the translations.
4. Verify that the string for the top banner is assigned correctly. The default language should be English, and then it should be translated to French. For guidance on how to change the source language of strings, visit: How to change the source language of strings.
If these steps do not resolve your issue or if the solution seems outdated or irrelevant to your case, we highly recommend checking related known issues at https://wpml.org/known-issues/, verifying the version of the permanent fix, and confirming that you have installed the latest versions of themes and plugins. If needed, please open a new support ticket at WPML support forum for further assistance.
This topic contains 0 replies, has 3 voices.
Last updated by bonnieK-2 2 months ago.
November 16, 2024 at 11:57 pm #16411263 | |
bonnieK-2 |
November 17, 2024 at 7:52 am #16411422 | |
Christopher Amirian Supporter
Languages: English (English ) Timezone: Asia/Yerevan (GMT+04:00) |
Hi, I will try to answer the question before assigning the ticket to one of my colleagues. Would you please follow the steps below? - IMPORTANT STEP! Create a backup of your website. Or better approach will be to test this on a copy/staging version of the website to avoid any disruption of a live website. See if it fixes the issue for you. Thanks. |
November 17, 2024 at 7:26 pm #16412046 | |
bonnieK-2 |
Hello, Please HELP! |
November 18, 2024 at 9:06 pm #16416534 | |
Andreas W. Supporter Languages: English (English ) Spanish (Español ) German (Deutsch ) Timezone: America/Lima (GMT-05:00) |
Hello, Could it be that this issue occured after updating to WordPress 6.7? If so, please read the following errata: Possible workaround: Best regards |
November 19, 2024 at 2:47 am #16417309 | |
bonnieK-2 |
Hello Andreas, Because my Staging site is only a few days old, I can not revert back using Jetpack to a previous version (before the update on November 12). This is what WordPress said about reverting back with Jetpack: I then asked them when the update for the next version will be released and they said: "I can see it's in the works already. Based on the release history, the first update is released within a week or two: Since 6.7 was released last week, the update might be released next week." So, what I want from you, because I am not a technical expert, not even a developer, is for you to look at https://core.trac.wordpress.org/ticket/62337, and tell me if you can see from the code generated by my site, if what they are talking about in this ticket, is indeed happening on my site. If it is not, lets investigate what is happening on my site. Thank you, |
November 19, 2024 at 10:11 am #16418646 | |
Hi, I would like to request temporary access (wp-admin and FTP) to the site to investigate the issue further. The required fields are below the comment section when you log in to leave the next reply. The information you provide is private, meaning only you and I can see and access it. IMPORTANT If you can't see the "wp-admin / FTP" fields, your post and site login details will be set to "PUBLIC". DO NOT publish the data unless you see the required wp-admin / FTP fields. The private reply form looks like this: The next time you reply, click on "I still need assistance". Video: Please note that we are obliged to request this information individually on each ticket. We are not allowed to access any credentials that were not specifically submitted on this ticket in the private response form. Best regards |
November 19, 2024 at 4:59 pm #16420884 | |
bonnieK-2 |
Hello Again Andreas, |
November 19, 2024 at 6:01 pm #16420992 | |
bonnieK-2 |
ATTENTION: I gave you an old password for the FTP access! the new one is: Mzk5YFNfPkUD4HNeMvmS Sorry, |
November 19, 2024 at 6:50 pm #16421113 | |
Hi Bonnie, The password for accessing WordPress is sadly incorrect. Could you please have a quick look into this? The private reply form is enabled again. Best regards |
November 19, 2024 at 10:32 pm #16421804 | |
My apologies, but the password still appears to be incorrect for the provided username. The private reply form is enabled again. |
November 20, 2024 at 5:19 pm #16425966 | |
I see, it is that those are your wordpress.com credentials, and not the credentials for the specific site. I was able to connect now. According to the translation status icon, the original homepage had been updated and the translation needed an update. (icon shows arrowed circle) The review for the translated homepage is not available at WPML > Translations. |
November 20, 2024 at 11:04 pm #16426705 | |
bonnieK-2 |
Hi Andreas, Sorry, screenshot 352 is not relevant and I uploaded it by mistake. What are you seeing? Are you seeing a French site with all the translations including the top bar? Thank you, |
November 20, 2024 at 11:49 pm #16426875 | |
bonnieK-2 |
Hi Andreas, |
November 21, 2024 at 3:31 am #16427209 | |
I can not confirm any issue viewing the French Homepage in a browser like Google Chrome. Browsers like Thor can not be used as reference, as they might block important language cookies used by WPML to determine the language of the page when not beeing logged in as a user. The string for the top banner is assigned to the default language French. You need to adjust it to have the default language English and then translate it to French. |
November 25, 2024 at 6:49 pm #16441802 | |
bonnieK-2 |
Thank you |
