Home›Support›English Support›[Resolved] ISSUE When using WPForms Multilingual 0.4.0 and WPforms Notification WITH attatchment
Problem: If you're experiencing issues with WPForms Multilingual where attachments are removed from notification emails, it might be due to a conflict with another plugin or theme. Solution: We recommend trying the following steps to identify and resolve the issue: 1) Create a copy or staging site for testing. 2) Disable all plugins except WPForms and test if the problem persists. 3) If the issue remains, switch to a default theme like Twenty Twenty-One to check if the theme is causing the conflict. 4) If the problem still isn't resolved, begin reactivating plugins one by one or in small groups to pinpoint the problematic plugin.
If these steps do not resolve your issue, or if the solution seems outdated or irrelevant to your case, we highly recommend checking related known issues at https://wpml.org/known-issues/, verifying the version of the permanent fix, and confirming that you have installed the latest versions of themes and plugins. If necessary, please open a new support ticket at WPML support forum for further assistance.
I am trying to use WPForms and WPForms Multilingual 0.4.0 to send notification emails with attachments. This is crucial for us as we use multilingual forms that require lots of attachments by email. The issue can be seen here: hidden link
Screen_Cast of the ISSUE : hidden link
When using WPForms Multilingual, the attachments are removed from the notification emails every time. When WPForms Multilingual is off, the attachments stay.
Why are attachments removed from notification emails when using WPForms Multilingual?
How can I ensure attachments are included in emails when using WPForms Multilingual?
Hey, I loaded my Elite Licence and Copied my FORM, unfortunately, i have the same issue. I load all the Attachement, Save and when i Go back to the form the Attachements are gone (unsaved).
Then, i deactivated the WPForms Multilingual, added the attachement, saved, exited and cam back and the files where still saved.
Languages: English (English )Spanish (Español )German (Deutsch )
Sorry for the misunderstanding.
I can see the issue on your imported form, but not on my "test" form.
Can you please confirm, if you can replicate the issue on the form called "test" on my test site?
One-Click-Login: hidden link
If not, then I will need to run tests with your imported form and try to figure out when exactly this issue occurs. It might happen only if specific fields and settings are used in combination.
Hey, If you check out the Video I made in the previous post, you'll see that i indeed tried on your TEST form. With and Without the plugin on (ans on a Guest Chrome).
I see that the Plug in WP forms translation was deactivated. Could you test again with the plugin Activated?
I re-tested with your TEST form with a Chrome Guest Browser (Zero Cache, Zero History, Zero Extentions) and a Safari browser in incognito mode... still the issue.
I seemed to work on your test site but, after the update on my production site, Still the same issue (i cleared the cache). I downgraded to 0.3.6 again
You mean "Field Label" in WPforms ?
They are all unique already :/
Manage Cookie Consent
Functional
Always active
Preferences
Statistics
Marketing
