Last updated by Bigul 3 weeks, 1 day ago.
Assisted by: Bigul.
August 29, 2024 at 12:26 pm #16119878
louiseD-7
I want to report two issues. First, I am trying to set an Archive Page where all sold products are displayed (hidden link and hidden link). I use a shortcode.
Here is the shortcode: function afficher_produits_stock_zero() { $args = array( 'post_type' => 'product', 'posts_per_page' => -1, 'meta_query' => array( array( 'key' => '_stock', 'value' => '0', 'compare' => '=' ) ) ); $query = new WP_Query($args); $output = ''; if ($query->have_posts()) { $output .= '
'; while ($query->have_posts()) : $query->the_post(); global $product; $output .= '
'; $output .= ''; $output .= str_replace('<img ', 'get_image()); $output .= ''; $output .= '
' . get_the_title() . '
'; $output .= '
'; endwhile; $output .= '
'; } else { $output .= '
Aucun produit en rupture de stock.
'; } wp_reset_postdata(); return $output; } add_shortcode('produits_stock_zero', 'afficher_produits_stock_zero');
The English page displays only the products that were sold (stock:0) in English, and the French version displays only the products sold in French. Additionally, when I deactivate WPML, the website doesn't show anything except the landing page.
How can I display all sold products in both languages on the Archive Page (archive is not the shop)?
Why does the website only show the landing page when WPML is deactivated?
August 29, 2024 at 5:32 pm #16121583
Bigul
You can list posts in both languages by adding the suppress_filters => true parameter in the query. Setting the "suppress_filters" query variable will help your theme display results from all languages. Please refer to the following tickets for more details.
https://wpml.org/forums/topic/search-results-from-other-languages-not-displaying/#post-8674273
https://wpml.org/forums/topic/how-to-make-wordpress-search-posts-and-pages-in-all-language/#post-13901871
When WPML is deactivated, all translated posts and pages are considered as part of the default language and will be listed normally. So could you please share a couple of screenshots or a screencast to better understand the following?
Bigul
The topic ‘[Closed] Issues with products display’ is closed to new replies.
