Home›Support›English Support›[Resolved] Activating the multi-site function after a domain change creates problems
Yesterday I tried to activate the Multi-domain functionality, it all seems to work wonderfully, but for one exception: When I activate the multi-domain functionality, all the wp-admin ajax calls are done to the first domain (covid19.groupealliances.com)
There is issue when you use “Different domains per language” and Nginx server configured with server_name that does not match your domain name.
Replace:
$url_parts['host'] = $_SERVER['SERVER_NAME'];
- in wp-content/plugins/sitepress-multilingual-cms/classes/url-handling/converter/strategy/class-wpml-url-converter-domain-strategy.php
yes that was the case when I tested it, but maybe I was not doing replicating steps correctly since I haven't used real domains but hosts manipulation.
Let's wait for an update from our developers, maybe they will be able to replicate it correctly.
I will update you as soon as I have some information.
It seems there is issue when you use “Different domains per language” and Nginx server configured with server_name that does not match your domain name.
Can you please try next workaround:
Replacing SERVER_NAME with HOST_NAME:
Glad to hear your issue is now solved, I will be sharing your fix with our developers.
I will be closing this ticket and marking it as resolved.
I hope I was helpful. Don't hesitate to ask if you find any problem in the future, I'll gladly help you.
Drazen
Manage Cookie Consent
Functional
Always active
Preferences
Statistics
Marketing
