Last updated by geertP 1 year, 9 months ago.
Assisted by: Osama Mersal.
February 21, 2023 at 3:51 pm #13080859
geertP
A website we have created needs to be translated in 2 other languages. A long time ago a former employee has installed Polylang on it but almost no translation were added.
Now we have to start adding translations, we decided to work with WPML (what we normally always do).
I have uninstalled Polylang and installed WPML. Set up everything but now when I would like to start translating, the content blocks from Gutenberg are not showing. With the classic editor it does work.
The yoast blocks are showing well.
Because this is a live website, I've duplicated the website to a test-environment.
The temporary URL is hidden link
I can give you admin access.
Kind regards
Geert
February 22, 2023 at 7:58 am #13085603
Osama Mersal
Hi Geert,
Please let me know which page is the problematic page.
Also, I would need to look closely at your site, so I would need to request temporary access (WP-Admin and FTP)
Your next answer will be private, which means only you and I can access it.
Osama
February 22, 2023 at 8:34 am #13086049
Osama Mersal
Hi Geert,
Thanks for the access details. You use ACF blocks and don't have ACF Multilingual installed, so please install it and check the following guides.
1) https://wpml.org/documentation/related-projects/translate-sites-built-with-acf/
2) https://wpml.org/documentation/related-projects/translate-sites-built-with-acf/recommended-custom-fields-translation-preferences-for-acf-and-wpml/
After setting the translation preferences for the custom fields, please update the page in the default language and translate it to check if the strings will appear in the translation editor.
Osama
February 22, 2023 at 10:25 am #13087341
geertP
Hi Osama,
I think it's solved.(didn't test it very well yet)
I installed the plugin.
That didn't solved the issue immediately.
I deactivated 'loco translate' plugin.
From that moment I get to see all my fields in the Advanced translation editor.
