After updating to WPML 4.7.4 and String Translation 3.3.3, issues arose with post categories not being recognized correctly on the front end when using Elementor. Disabling String Translation temporarily resolved the issue, indicating a compatibility problem between the updated versions of WPML, String Translation, and Elementor.
We identified that the issue stems from Elementor using
term_taxonomy_id
instead of
term_id
, which our code did not anticipate, leading to all results being shown without filtering by a taxonomy term. A fix for this issue will be included in the upcoming WPML 4.7.5 release. Meanwhile, we provided a workaround involving a code modification in
/sitepress-multilingual-cms/addons/wpml-page-builders/classes/Integrations/Elementor/Hooks/QueryFilter.php
. This modification should be tested on a staging site after taking a full backup. If this solution does not resolve your issue or seems outdated, please check for related known issues at https://wpml.org/known-issues/, verify you have the latest versions of themes and plugins, and if necessary, open a new support ticket at WPML support forum.
This topic contains 32 replies, has 1 voice.
Last updated by 9 months, 2 weeks ago.
