Problem: If you're experiencing issues with your website appearing broken on Arabic pages, it's likely due to the theme styling not being properly configured for RTL (Right-to-Left) languages. Solution: We recommend checking the RTL styles of your theme. Typically, websites use a
style.css
file for LTR (Left-to-Right) languages and a
style-rtl.css
file for RTL languages. If the
style-rtl.css
is not properly set up, it can cause display issues on RTL language pages. You should reach out to your theme developer to address this issue or consider using a theme that supports RTL languages.
Welcome to WPML support. I'd be happy to help you with this.
Can you provide me with more information about the issue, links, and screenshots will be helpful.
Further, We've recently rolled out a new version of WPML plugins. Could you please update your plugins to the latest version and inform me if it resolves the issue?
Our WPML updates are distributed gradually. If your websites haven't received this update yet, please be patient, and you should see it within a few days.
To debug this issue further, I would need to check your site settings once, for this I would need temporary access (wp-admin and ftp) to your site.
So could you please provide me with those details, you will find the needed fields for this below the comment area when you log in to leave your next reply. hidden link
This is not a WPML issue rather than your theme styling issues, on other languages, the sites use LTR direction which is styled by using style.css, and in Arabic RTL direction is used and style-rtl.css is used.
The RTL styles aren't created properly so it looks broken, please contact the theme developer to fix this or use a RTL supported theme.
What I see is that with the Arabic language my website does not load the Tailwind library and that is why the website does not have styles. Doesn't it have anything to do with WPML?
As mentioned I don't think it's WPML issue, You can disable WPML and set the WordPress language to arabic to confirm this.
Manage Cookie Consent
Functional
Always active
Preferences
Statistics
Marketing
