The client was experiencing an issue where scheduled posts were being published in all the languages they translate to (Spanish, German, and Portuguese), but only the title was getting translated.
the issue has been permanently fixed in WPML version 4.6.10, so after updating to this version, no further action should be necessary.
Please note that this solution might be irrelevant if it's outdated or not applicable to your case. If you're experiencing similar issues, we highly recommend checking the related known issues, verifying the version of the permanent fix, and confirming that you have installed the latest versions of themes and plugins. If the problem persists, please open a new support ticket.
This topic contains 14 replies, has 4 voices.
Last updated by Alejandro 1 year, 4 months ago.
Assisted by: Alejandro.
January 4, 2024 at 11:37 am #15150337 | |
lucaD-42 |
This is the continuation of the issue that has been closed I finally found the bug, the problem happens when items are scheduled. Can you find a solution please? Please read the whole previous tread well so as not to repeat everything, the person who followed me is Andreas. Thanks Luca |
January 4, 2024 at 1:55 pm #15150969 | |
Alejandro WPML Supporter since 02/2018
Languages: English (English ) Spanish (Español ) Italian (Italiano ) Timezone: Europe/Rome (GMT+02:00) |
Hi there! i'm glad you managed to find where the bug is. now, can you tell me the steps you take to first schedule the post? you can record a quick video and share it with me if it's easier or faster or you can try to recreate the problem on a new installation such as this one: hidden link Try to configure WPML with the languages o your site and create + schedule a page/post and see if the problem happens here as well. if it does, please write here the steps so i can then figure out why is it not working and how we can fix it for you. Thanks. |
January 4, 2024 at 4:38 pm #15152431 | |
lucaD-42 |
Hi Alejandro, I prefer to make the video on my system, it is the only way to see the bug in the real environment. You can see how we schedule here: tomorrow the article will not be translated automatically but published with only the tile translated, as you can see from the previous tread. (I attached a previous screenshot). Tomorrow I will send you the screenshot of the new "non translated article". Ty |
January 5, 2024 at 8:41 am #15153506 | |
I had missed that you were Italian so i'll write in Italian from here onwards in case it's better for you (answer in English if you want to continue in English, instead). Con questa info è più che sufficente, volevo vedere se facevi qualcosa di particolare ma non è stato il caso. Sto facendo un test e appena ho i risultati ti risponderò. |
January 5, 2024 at 10:07 am #15153779 | |
Ho ricreato il problema e l'ho inviato ai nostri sviluppatori per vedere come possiamo risolverlo, non c'è necessità che mi invii altro. Ti terrò aggiornato. |
January 5, 2024 at 10:25 am #15153857 | |
lucaD-42 |
Grazie Aljandro, Nel mentre ti mando gli screenshots di oggi che ti fanno vedere come l'articolo presenti il problema quando è schedulato. Il post viene pubblicato in tutte e tre le lingue in cui traduciamo (spagnolo, tedesco e portoghese) ma solo il titolo viene tradotto. Altra informazione che forse ti è utile : per risolvere il bug devo aprire l'articolo in elementor modificare qualcosa e salvare, fatto questo tutte le traduzioni si "aggiustano". Un piccolo trick che mi aveva suggerito il tuo collega nell'altro tread. In attesa ti saluto Luca |
January 5, 2024 at 2:01 pm #15154908 | |
puoi anche farlo da WPML > Translation Management ed inviare la pagina da lí (questo funziona meglio quando ce ne sono tante pagine, così fai solo un'unica operazione). Si ritradurrebbe automaticamente (Senza farti pagare niente) e avresti lo stesso risultato che quando fai qun cambiamento alla pagina e lo salvi (che fa la stessa cosa). Comunque grazie per queste info che ci hai fornito. è definitivamente un bug e i nostri sviluppatori ci stanno lavorando per vedere come risolvere il problema. Ti terrò aggiornato. |
January 6, 2024 at 10:14 pm #15157026 | |
lucaD-42 |
Hai qualche notizia? Grazie e scusa il disturbo Luca |
January 8, 2024 at 10:25 am #15159575 | |
Ancora niente ma spero poter avere una risposta entro domani. ti aggiorno appena mi rispondono. |
January 14, 2024 at 10:11 am #15182070 | |
lucaD-42 |
Any news? |
January 15, 2024 at 8:29 am #15183540 | |
We're almost there, out Devs are still checking the problem out |
January 16, 2024 at 1:07 pm #15189868 | |
Laura WPML Supporter since 05/2018
Languages: English (English ) Italian (Italiano ) Timezone: Europe/Rome (GMT+02:00) |
Ciao, Alejandro è in ferie e lo sostituisco io. Abbiamo un workaround return defined( 'WPML_TM_VERSION' ) && ( is_admin() || ( defined( 'XMLRPC_REQUEST' ) && constant( 'XMLRPC_REQUEST' ) ) || wpml_is_rest_request() ); con return defined( 'WPML_TM_VERSION' ) && ( is_admin() || ( defined( 'XMLRPC_REQUEST' ) && constant( 'XMLRPC_REQUEST' ) ) || wpml_is_rest_request() || (defined('DOING_CRON') && DOING_CRON) ); - apri il file \wpml-string-translation\inc\package-translation\inc\wpml-package-translation.class.php if ( is_admin() || $this->is_doing_xmlrpc() || wpml_is_rest_request() ) { con if ( is_admin() || $this->is_doing_xmlrpc() || wpml_is_rest_request() || (defined('DOING_CRON') && DOING_CRON) ) { e dovresti risolvere. Cercheremo di inserire il fix nella prossima versione di WPML. |
January 17, 2024 at 4:35 pm #15196092 | |
Pieter |
Thanks for the temporary workaround! > Cercheremo di inserire il fix nella prossima versione di WPML. Since 4.6.9 came out 6 days before this workaround, when can we expect that this makes it into the next update(s) please? |
February 1, 2024 at 3:25 pm #15255654 | |
Al momento non abbiamo una data di rilascio per la prossima versione di WPML, mi spiace |
April 4, 2024 at 2:26 pm #15484261 | |
Ciao! Volevamo informarti che il problema è sistemato permanentemente nella versione 4.6.10 quindi una volta aggiornato, non dovrai fare altro. Saluti. |
