Supporter timezone: Africa/Cairo (GMT+02:00)
This topic contains 16 replies, has 3 voices.
Last updated by Osama Mersal 1 year, 9 months ago.
Assisted by: Osama Mersal.
January 28, 2023 at 9:47 am #12908507
edwinO-3
When using automatic translation bundled products do not get translated/copied correctly.
Example:
The original Dutch Product Bundle:
The translated English Product Bundle:
Notice the product tile and description of the bundled products.
See attached images of front end and CMS
January 29, 2023 at 8:26 am #12910947
Osama Mersal
Please create a test product named "WPML Test" and replicate the issue to check it.
Also, I would need to look closely at your site, so I would need to request temporary access (WP-Admin and FTP)
Your next answer will be private, which means only you and I can access it.
Osama
February 2, 2023 at 8:24 am #12944513
edwinO-3
Hi Osama,
that's kind of difficult to do right now. But basically you confirm that all those settings should be the same on the automatically translated products. I wasn't sure about that.
We have a lot of product bundles, basically all you see here: hidden link
We will create more of those next week, so we'll check if they translate correctly with all settings in place. Because we noticed a few that didn't have the 'priced individually' checked, which is very bad as the products won't be charged to the customer.
Kind regards,
Edwin
February 2, 2023 at 8:28 am #12944535
Osama Mersal
Hi Edwin,
Thanks for your update. The fields should be copied, but to be sure, please go to WPML-> Settings-> Custom Fields Translation section, search for these fields, and make sure that they are set to Copy.
Osama
February 2, 2023 at 10:53 am #12946229
edwinO-3
I can't really find those fields, do you know what fields to look for? We're talking about this plugin:
https://woocommerce.com/products/product-bundles/?quid=d1614849f462b6ed9cac5037e9b94111
February 2, 2023 at 11:04 am #12946393
Osama Mersal
Would you please login to this sandbox site and upload the plugin? (hidden link)
After that, please create a test product and translate it to replicate the issue. If the issue is replicable, please let me know the steps to reproduce the issue.
Osama
February 2, 2023 at 3:12 pm #12948975
edwinO-3
Osama,
I tried to do that, but in the sandbox there is no Woocommerce installed, Automatic translation cannot be activated (unless I add our credit card) etc.
Kind regards,
Edwin
February 3, 2023 at 10:52 am #12954627
Osama Mersal
Hi Edwin,
I installed WooCommerce Multilingual. Could you please create the products in the default language, and I'll translate them?
Osama
February 10, 2023 at 7:07 am #13004347
edwinO-3
the sandbox is no longer available. Can you recreate it?
February 10, 2023 at 11:07 am #13006255
Osama Mersal
Here is a new sandbox site. (hidden link)
Osama
February 10, 2023 at 1:41 pm #13007231
edwinO-3
I created 2 simple products and 1 product bundle. And set the options of the products similar to what we do here.
Kind regards,
Edwin
February 10, 2023 at 2:08 pm #13007431
Osama Mersal
Hi Edwin,
Thanks for creating the products. I translated them, and the custom title and description appeared correctly in the translation editor. (Kindly check the attached screenshot)
After the translation, I edited the German bundled product, and the settings were copied correctly. Would you please check the products in both languages and let me know if you can see the same issue?
Osama
February 13, 2023 at 11:39 am #13019651
edwinO-3
Yes, but we let those products translate automatically. We chose DeepL automatic translations, I think the problem is there. If you translate manually it is different, because you would of course also translate the custom title and description within the product bundle.
February 13, 2023 at 12:01 pm #13019747
Osama Mersal
I created a new product, and it's translated using Automatic Translation. (hidden link)
It seems to work correctly; please check it and let me know.
The automatic translation is activated on the sandbox site; please try to replicate the issue.
Osama
February 15, 2023 at 12:38 pm #13040053
edwinO-3
Yes, I see it works in the sandbox in this case.
The topic ‘[Closed] Bundled products options are not copied to translated products’ is closed to new replies.
