The client is facing an issue where a checkbox is not appearing at checkout in Greek on their WooCommerce site, although it appears in English.
We have identified that the issue is not caused by WPML. The problem arises because WooCommerce blocks rely on JavaScript translation files (.json files), which are not fully supported by WPML String Translation. Consequently, the site loads the native WooCommerce translations. In this case, the Greek translation for that string is incomplete. To address this, you can contribute to completing the translation at WordPress translation project.
If this solution does not apply to your case, or if it seems outdated, we recommend opening a new support ticket. We also highly recommend checking related known issues at WPML Known Issues, verifying the version of the permanent fix, and confirming that you have installed the latest versions of themes and plugins.
