Last updated by Bruno Kos 1 year, 11 months ago.
Assisted by: Bruno Kos.
May 24, 2023 at 9:57 am #13705869
Alex Karpov
Since BeTheme became the main theme for our websites, we have been developing the project hidden link. Starting from approximately 2015, many plugins were installed and deleted by mistake. Now we have firmly transitioned to the absolute minimum, where only Kadence Product and Rank Math SEO optimization are the foundation.
Now that we have learned to maintain internal cleanliness, we have noticed that a lot of junk records are still stored in the database: options, posts, and debugging information.
To clean them up, we want to clarify two questions. Can you take a look and help us do this?
If not, what is the most convenient way to save only translations without custom fields? I emphasize that it is only translations so that we can load them on a new installation.
Current Plugin List:
Akismet Anti-Spam Version 5.1 by Automattic | Auto-updates disabled
Code Snippets Version 3.4.0 by Code Snippets Pro | Auto-updates disabled
Cyr-To-Lat Version 5.5.2 by Sergey Biryukov, Mikhail Kobzarev, Igor Gergel | Auto-updates disabled
Forminator Version 1.23.3 by WPMU DEV | Auto-updates disabled
Kadence Blocks - PRO Extension Version 1.7.29 by Kadence WP | Auto-updates disabled
Kadence Blocks – Gutenberg Blocks for Page Builder Features Version 3.0.38 by Kadence WP | Auto-updates disabled
Kadence Custom Fonts Version 1.1.5 by Kadence WP | Auto-updates disabled
Kadence Pro - Premium addon for the Kadence Theme Version 1.0.9 by Kadence WP | Auto-updates disabled
LiteSpeed Cache Version 5.4 by LiteSpeed Technologies | Auto-updates disabled
ManageWP - Worker Version 4.9.17 by GoDaddy | Auto-updates disabled
Rank Math SEO Version 1.0.115 by Rank Math | Auto-updates disabled
True Lazy Analytics Version 2.3 by seojacky | Auto-updates disabled
weDocs Version 1.7.1 by weDevs | Auto-updates disabled
WP Mail SMTP Version 3.8.0 by WP Mail SMTP | Auto-updates disabled
WPML CMS Nav Version 1.5.5 by OnTheGoSystems | Auto-updates disabled
WPML Media Version 2.7.2 by OnTheGoSystems | Auto-updates disabled
WPML Multilingual CMS Version 4.6.3 by OnTheGoSystems | Auto-updates disabled
WPML Sticky Links Version 1.5.4 by OnTheGoSystems | Auto-updates disabled
WPML String Translation Version 3.2.5 by OnTheGoSystems | Auto-updates disabled
May 24, 2023 at 3:07 pm #13709025
Bruno Kos
Can you check this?
https://wpml.org/documentation/getting-started-guide/language-setup/deleting-languages-and-plugin-data-by-doing-a-wpml-reset-on-your-site/
This is as far as it goes with deleting WPML data that we have within our documentation and is officially supported.
As for WPML settings, you could check wp_options for entries that have icl_ within, this is where some of the information is stored, such as WPML settings.
However as for removing custom fields but keeping translations, this does not work, it'll be like keeping original pages but trying to remove custom fields, this would most likely break the layout or cause other unforeseen problems.
Bruno Kos
May 24, 2023 at 11:46 pm #13711775
Alex Karpov
Hey Bruno. Thanks for the quick reply.
That what we think about to start from scratch, but it seem, that we loose all translations which was done in WPML Advanced Translation.
All translation done by Advanced Translation editor, still create strings in String Translation as untranslated why?
Best, Alex
May 25, 2023 at 9:58 am #13714927
Bruno Kos
Yes, if you reset WPML you will lose translation memory because the website will not be connected to ATE no longer, so you need to use this carefully.
Can you show me a screenshot of this?
Bruno Kos
The topic ‘[Closed] Clean up after 7 years of using WPML’ is closed to new replies.
