Supporter timezone: America/Los_Angeles (GMT-08:00)
Last updated by Bobby 6 months ago.
Assisted by: Bobby.
July 17, 2024 at 2:42 pm #15966851
bjornB-33
I am continuously facing issues with link and string translations on my site hidden link. Despite following all the recommendations in your documentation, the links are still leading to the German site. I have tried all the troubleshooting steps provided.
The links are still leading to the German site despite following all the recommendations and troubleshooting steps.
Is there any other solution than going through each site and manually setting the links again?
July 17, 2024 at 2:47 pm #15966908
bjornB-33
hello?
July 17, 2024 at 6:22 pm #15967882
Bobby
Timezone: America/Los_Angeles (GMT-08:00)
This is irrelevant to the issue but please review the SSL certificate as the site seems to point to Https but the EN version comes up without it causing some errors.
Thank you,
Bobby
July 26, 2024 at 6:13 am #16006761
Bobby
I was able to reproduce the issue and we are currently reviewing this.
July 26, 2024 at 6:49 am #16006933
Bobby
If possible, please go to Appearance->Themes and update Uncode to the latest version along with the WP Bakery Page builder.
The latest version comes with a few updates.
Typically adding this XML should solve this issue but what it did not during my tests.
Once you update, please do a quick test using the test pages I created, you can simply add a button->set a URL and translate.
<wpml-config>
  <shortcodes>
    <shortcode>
      <tag>vc_button</tag>
      <attributes>
        <attribute encoding="vc_link" type="link">url</attribute>
      </attributes>
    </shortcode>
  </shortcodes>
</wpml-config>
August 8, 2024 at 3:00 pm #16053538
bjornB-33
hey, thank you, i updated the theme. But i am a bit lost here:
"Once you update, please do a quick test using the test pages I created, you can simply add a button->set a URL and translate.
<wpml-config>
<shortcodes>
<shortcode>
<attributes>
</attributes>
</shortcode>
</shortcodes>
</wpml-config>
WHERE CAN I ADD THE XML? thank you very much
August 8, 2024 at 4:58 pm #16053917
Bobby
Please go to WPML->Settings->Custom XML Configuration tab at the top
Once you add it you can save it and it will take effect.
The topic ‘[Closed] Continuous Issues with Link/String Translation on My Site’ is closed to new replies.
