Last updated by Andreas W. 1 year, 9 months ago.
September 28, 2023 at 7:20 am #14479063
patrikB-13
I am trying to: Translated custom footer from Slovak from English
Link to a page where the issue can be seen: multiple pages including hidden link
I expected to see: The translated custom footer
Instead, I got: Either the default Avo theme footer or the translated custom footer, it's different from page to page
September 29, 2023 at 11:28 pm #14490329
Thank you for reaching out!
Please go to WPML > Settings > Custom Field Translation and look for a field that is related to the footer layout settings.
Make sure to set this field to "Copy".
Guide:
From now on, once you translate a page, the theme options that control the footer layout should be copied from the original content to the translated language.
If this will still not solve the issue, let me know.
October 2, 2023 at 12:57 am #14493967
patrikB-13
Thank you for your reply,
I did change the custom translation field for avo_footer_format and avo_footer_list to copy, but it didn't resolve the issue.
October 3, 2023 at 3:38 pm #14506793
Thank you for your message.
I do have a couple of questions:
Did you try to translate the page again after adjusting the settings?
Your footer template is translated to 100%?
The topic ‘[Closed] Custom Elementor footer problem’ is closed to new replies.
