Our wait time is higher than usual, please make sure you are meeting the minimum requirement - https://wpml.org/home/minimum-requirements before you report issues, and if you can take a look at current Known Issues - https://wpml.org/known-issues/. Thank you.
Last updated by Dražen 1 week, 5 days ago.
Assisted by: Dražen.
March 25, 2025 at 11:11 am #16856736
kostasT-4
I am using WP Job Manager which creates 3 custom post types (Job, Resume, and Company). I have set all of them as non-translatable, and I want to add some taxonomies (that are translatable and fully translated already) to these posts. The issue can be seen at hidden link. I expected that when a user submits a new resume, they can add a category to it, and the resumes can be filtered with this category in the search page, working in both languages with the filters shown in the correct language.
Initially, it was working fine, but now when a new resume is submitted, it only adds the taxonomy term of the current language. When I change the language and edit the resume, I can manually add the translated taxonomy, but then it appears twice in the correct language on the single page.
Why is the taxonomy term added only in the current language when a new resume is submitted?
How can I ensure that both the original and translated taxonomy terms are automatically added to the post, no matter the selected language?
How can I get on the single post, only the taxonomy terms of the current language and not the translated ones too?
March 26, 2025 at 7:49 am #16860795
Dražen
thanks for contacting us.
I am afraid what you are trying to do is not recommended and issues you have are expected.
You have a post type not translatable, but taxonomies do, so you are trying to assign 2 language taxonomies to 1 language post. What you have is expected issues; you can assign manually other translated taxonomies, but that will also show as it is assigned.
Best would be to either set both, post types to translatable so they can have translated taxonomies assigned, or set both post type and taxonomy as not translatable.
Hope this helps,
Drazen
March 26, 2025 at 1:46 pm #16863169
kostasT-4
Thanks for the reply! I see the problem. I think that having both as non-translatable is the way to go.
Is there a way to translate only the term names on the string translation page and keep the same ID slug, etc? I have tried registering the strings with wpml_register_single_string, but the term names appear in so many places (plugins and themes), so it is impossible to go to each one of them and use wpml_translate_single_string to show the translated version.
Is there a better way to find the taxonomy terms in the string translation page, so that they appear automatically translated where they are supposed to?
March 27, 2025 at 7:18 am #16866272
Dražen
what do you mean by term? Is this some taxonomy also added to this post types, if yes then it should be not translatable also.
In general, taxonomy translations are done via WPML > Taxonomy, or are automatically translated when the page it is assigned to, is automatically translated.
Let me know.
Drazen
