Last updated by Shekhar Bhandari 1 day, 9 hours ago.
April 23, 2026 at 5:04 pm #17991006
bergmans23
Hi WPML friends,
I'm building a smal site in 5 languages for a client of mine and just before going live, they ask me to change the slugs of a custom post type.
No problem, but after changing the slug, 4of the 5 language versions of these posts disappear.
I jumped back to a backup version, but before trying it again, I would like to ask you for help!
Thanks in advance!
Bye
Ward
April 24, 2026 at 8:53 am #17992170
Shekhar Bhandari
WPML Supporter since 03/2015
Hello there,
Thank you for contacting WPML support. I'd be happy to assist you on this issue.
After changing the CPT, could you please go to WPML-> Support ->Troubleshooting and click the below buttons:
+ Clear Cache in WPML
+ Set Language information
+ Fix element types collation
+ Remove ghost entries from the translation tables
+ Assign translation status to duplicated content
Does this help? if not, to debug this issue further, I would need to check your site settings once, for this I would need temporary access (wp-admin and ftp) to your site.
Note:
Look forward to your reply.
April 28, 2026 at 4:50 am #17998335
Shekhar Bhandari
Hello there,
Thank you for your message.
Are you referring to custom post types (product groups)? Could you please show how you are modifying the product slugs?
A video recording would be very helpful so I can replicate the issue on my end.
May 5, 2026 at 5:36 pm #18014963
bergmans23
Hello Shekhar,
Thanks for your answer.
Strange thing; the updates on this ticket do not reach me through email. But the questions if the ticket is solved do!
The way I go about it is:
Change the translation setting of the post type "prodcut group" to translatable and even translate the slugs there.
Click CPT UI >> Add/Edit post types >> Edit post types and choose "product-group".
There I change the Post Type Slug, Plural Label and Singular Label, while toggling ON "Migrate posts to newly renamed post type".
This results in the 4 posts, formarly known as Product Groups, to get changed to post types with the new name, but only the 4 posts in the primary language ( english ). the versions in Dutch, German, French and Spanish are gone!
Hope you can help.
Bye
Ward
May 6, 2026 at 5:21 am #18015726
Shekhar Bhandari
Hello there,
Regarding the notifications, could you please go to the Notifications tab on the right side of this forum (bell icon) and enable them?
I can see the issue, and it looks like the migration done by the CPT plugin does not migrate the translations. Unfortunately, making this work would require significant work.
WPML maps translations based on the post ID and post type. In your case, the post type slug has changed, so WPML treats it as a completely new post type, and the previous translation mapping no longer applies.
You can try the following alternatives instead:
* Migrate all posts before changing the slugs, then import them after the change
* Deactivate WPML, migrate the posts, and reconnect them afterward as translations https://wpml.org/faq/how-to-link-already-translated-pages/
* If you used the WPML Advanced Translation Editor, you can open the translations again and the previous translated content should still be available, so you would only need to save them again.
Please let me know if this helps.
May 9, 2026 at 6:19 pm #18024582
bergmans23
Hi Shekhar,
Thanks! I can't find the bell icon or notifications, but I'll keep looking.
About the translations; I think the easiest way will be to to copy the texts of the 4 posts in all languages, dump them , change the slug and start over.
That will take less time and less risk I think.
I'll keep you posted.
Bye
Ward
May 11, 2026 at 7:13 am #18025938
Shekhar Bhandari
Hello 🙂
You should see the Notifications section on this same forum page.
If it is not visible on your end, could you please share a screenshot of the forum page so I can check it further?
I will wait for your response regarding the issue.
Custom-Post-Type-renaming-slug-translated-versions-of-post-type-disappear-WPML-05-11-2026_10_23_AM.jpg
