Supporter timezone: America/Los_Angeles (GMT-08:00)
Last updated by Bobby 1 year, 8 months ago.
Assisted by: Bobby.
May 1, 2023 at 3:33 pm #13565673
jean-francoisS-2
I recently got an issue removing a language from my site: https://wpml.org/forums/topic/delete-an-existing-language-on-my-website/
The person helped me clean the database but there seem to be posts that still exists because sometimes I see the same post twice when I use the search function on my site. They have 2 different ID but one of them is not related to any language on my site.
Is there a query I could run to delete all these posts that arent related to the 2 langauges on my site?
May 2, 2023 at 6:46 pm #13573763
Bobby
Timezone: America/Los_Angeles (GMT-08:00)
I would like to take a closer look at this to see where these duplicate pages are coming from.
Are you using the search function at the frontend or the backend of your site?
Share with me a search query if it's at the frontend so I can test this as well. Also feel free to share with me any screenshots you have of the results with the duplicated pages
May 3, 2023 at 8:32 pm #13581889
jean-francoisS-2
At the front, it is using the_search_query()
This is the url: hidden link
post ids : 44644 and 44604
May 4, 2023 at 7:18 pm #13589807
Bobby
Thank you, I can see them now.
Thank you,
Bobby
May 13, 2023 at 6:44 am #13639823
Bobby
Go to Posts->Categories-> Notice the categories are displayed twice.
Make sure to remove the duplicate category and test again
For example, I have removed RH et Business.
May 15, 2023 at 1:43 pm #13648539
jean-francoisS-2
Hi, after deleting the duplicated category on the live site, I still have the issue. I think none of the posts or page related to the removed language got deleted. For example here is a query with pages, product from woocommerce and posts duplicated : hidden link
May 17, 2023 at 4:21 am #13660195
Bobby
Thank you for updating me!
Please check this on the staging site, when I go to Articles->All articles -> French -> I can see certain articles showing twice.
For example the article Accélérer la mixité: entrevue avec Marie-Christine Mahéas was listed twice. Deleting the version not translated seems to have resolved this issue.
May 17, 2023 at 7:33 pm #13667917
jean-francoisS-2
I have reset the staging with a fresh copy of the live site after deleting the copied categories.
I did see the duplicated posts but I notice one of them does not have a linked translation. I think these posts come from the fr-EU lang that was deleted. Also, after removing the categories. All these posts are not showing up in the admin, but still appear in the search.
Is there some kind of query I could run to delete all the posts that dont have translations? Or is there another way to fix this?
May 18, 2023 at 1:38 am #13668635
Bobby
Yes, this happened most likely after the custom language was removed.
Same to as if you had RESET WPML, the content would have it's language code info removed and it would display under the default language.
While it may sound tedious the best way to resolve this is to go to Posts->All posts-> French language and delete the ones that do not have a translation.
You can bulk-select them and delete them.
Please try this with a few and let me know your results. Afterward, they should not display in the search query twice.
In the meantime, I will discuss this with our team and see if theres a possible query that could help.
May 23, 2023 at 4:21 am #13694445
Bobby
To add to my previous reply, I discussed this with our team and a SQL query for this type of issue would be quite dangerous as we could end up deleting the valid post rather than the duplicate.
Instead we suggest doing it using the bulk actions or with this plugin
https://wordpress.org/plugins/remove-duplicate-posts/
The topic ‘[Closed] Delete post not related to languages’ is closed to new replies.
