Last updated by olivierA-13 1 year, 9 months ago.
March 23, 2023 at 2:07 pm #13316007
olivierA-13
Hi
I am using the plugin "Element Pack Lite - Addons for Elementor" and in there the module "Static Carousel". Unfortunately it seems that the texts that I set up in my main language (EN) don't show up in my translations (PT). What can I do?
Thank you and best,
Olivier
March 24, 2023 at 6:42 am #13320249
You might need to register the widgets as explained here https://wpml.org/documentation/support/language-configuration-files/how-to-register-page-builder-widgets-for-translation/ .
Could you give it a try?
While checking your debug information, I noticed that your “WP Memory Limit” PHP limit is below the required 128MB or recommended 256MB as described at: https://wpml.org/home/minimum-requirements/ . Could you please contact your hosting provider and ask them to increase this PHP value for you?
