Last updated by Lucas Vidal de Andrade 1 year, 2 months ago.
February 22, 2024 at 1:00 am #15330836
krisW-4
When saving page - Enfold Code Block - adding <p> and </br> tags to my code - specifically styles - This only happens on not main language
Example:
<style>
.form-container {<br />
max-width: 600px;<br />
margin: auto;<br />
background-color: #fff;<br />
padding: 0px;<br />
}</p>
February 22, 2024 at 10:58 am #15332941
WPML Supporter since 11/2023
I checked your debug info and noticed that your website doesn't have the minimum memory required for WPML to work. WPML requires a memory limit of at least 128MB while 256MB is recommended. See https://wpml.org/home/minimum-requirements/ for detailed information. You can set WP Memory Limit in your wp-config.php file by adding following code:
define( 'WP_MAX_MEMORY_LIMIT', '512M' );
See:
https://wordpress.org/support/article/editing-wp-config-php/#increasing-memory-allocated-to-php
for details. Increasing WP Memory may help improve the performance and sometimes also help resolving such issues.
About the html tags themselves, one of my colleagues you soon come to assist you with it.
The topic ‘[Closed] Enfold Code Block – adding and tags to my code – specifically styles’ is closed to new replies.
