- 8:00 – 14:00 8:00 – 14:00 8:00 – 14:00 8:00 – 14:00 8:00 – 14:00 -
- 15:00 – 17:00 15:00 – 17:00 15:00 – 17:00 15:00 – 17:00 15:00 – 17:00 -
Supporter timezone: Europe/Madrid (GMT+02:00)
This topic contains 30 replies, has 0 voices.
Last updated by Paola Mendiburu 3 months, 3 weeks ago.
Assisted by: Paola Mendiburu.
December 22, 2025 at 9:42 pm #17683482
andreasC-8
i have 2 languages GR and EN. My main language is Greek, the products are imported to the website. Now the images are working properly but the English thumbanils on backend, emails , search are not shown .
December 23, 2025 at 12:05 pm #17684515
Carlos Rojas
WPML Supporter since 03/2017
1.- I kindly ask you to create a full site backup and then follow the steps described in this video: hidden link
2.- Please increase the WP memory Limit. Minimum requirements are 128Mb: https://wpml.org/home/minimum-requirements/
You can add this to wp-config.php to increase WP memory:`
/* Memory Limit */
You can double-check the WordPress memory limit in WPML -> Support
Can you tell me the results of the steps described above?
December 23, 2025 at 7:09 pm #17685498
andreasC-8
Thank you the issue is gone.
December 23, 2025 at 10:39 pm #17685749
andreasC-8
just getting back on the ticket to let you know that if i enable that option which automatically should take care of the images , it doesnt work on my case. Now the question is should i do this manual thing for each new product i add ?
We have thousand of products imported through imports, we cannot keep doing this manually .
Can you suggest a solution please?
December 24, 2025 at 9:06 am #17686141
Carlos Rojas
1.- Please share the URL of one of the products where the issue can be seen, and that we can use as a reference.
2.- Also, I kindly ask you to share the access credentials to the site in your next message, which I have set private. This will allow me to reproduce the issue and check the configuration.
December 26, 2025 at 12:13 pm #17688486
Carlos Rojas
Thank you for sharing the credentials requested.
I'm regenerating the WooCommerce thumbnails. This will take a while. Please double-check if the issue disappears when the process finishes.
December 26, 2025 at 4:04 pm #17688689
andreasC-8
Evsn if the problem is now gone. Everytime k will import products from wp all import i will face the same issue.
December 27, 2025 at 10:11 am #17689305
andreasC-8
Also , one more thing i noticed and i dont know if its related is that my English product imports are not assign to the correct cateogry but only on the main Language which is Greek.
posting couple of screenshots .
December 29, 2025 at 9:37 am #17694412
Carlos Rojas
Could you share an import file in Greek and the corresponding one in English so I can check the structure and run an import process? Please make sure the import files only have one or two products, as this will be only a test import.
December 29, 2025 at 2:49 pm #17695236
andreasC-8
you already have access to the backend . You can go to WPALLIMPORT -> Manage Imports.
You can do what ever you like, we have Greek imports and English .
Do your tests and let me know
December 30, 2025 at 10:40 am #17696489
Carlos Rojas
The import files in WPALLIMPORT contain a large number of products. I kindly request that you create a sample import file with one or two products in each language that we can use as a reference and share the download link in your next message.
December 31, 2025 at 7:40 pm #17698921
andreasC-8
Hello , you cannot recreate the problem with 1 or 2 products.
You can use the import with id 9(is in greek import) and 10 (in english). Which they have 27 products through CLI , with the following command.
wp all-import run 9,10 --force-run
This will finish in less than 2 minutes. Please let me share with you the CLI ip, user , and pass so you can run the imports through CLI.
Also i prefer to work on the specific imports which already have the BUG and the english translation doesnt work properly .
January 2, 2026 at 10:02 am #17700002
Carlos Rojas
Happy New Year!
1.- Could you explain what you mean by "you cannot recreate the problem with 1 or 2 products"?
2.- I need to download the import files to check the structure. It seems the files are stored in hidden link so I can't download them. Could you share a download link for the files with IDs 9 and 10?
January 2, 2026 at 5:53 pm #17700842
andreasC-8
I really dont understand what is the problem. You have the imports which are pointed to my supplier .xml which is remote url . The import templates are ready you can edit them, edit the settings and see the .xml fields as well.
I dont understand what are you trying to do ?
January 5, 2026 at 9:01 am #17702994
Carlos Rojas
I need to see the import XMLs on a local environment and test them in a sandbox site, if necessary. The import templates are important too, but I need to evaluate if the XMLs are malformed.
The topic ‘[Closed] English thumbs not working’ is closed to new replies.
