This topic contains 7 replies, has 1 voice.
Last updated by Bobby 1 year ago.
Assisted by: Bobby.
January 7, 2025 at 8:00 pm #16571343
Bobby
WPML Supporter since 04/2015
Thank you for updating me!
There is a possibility some IDs are "stuck" due to the organization changing so many times.
When a job has an ID that is originating in an organization that is not part of your current one it could cause such behaviors.
Would you like me to consolidate everything under one, or are you trying to keep the staging and live site ATE credits separate and under different organizations?
This won't affect anything as far as how the site is working in the front end it's just for our backend system and the credit system, meaning that if you see 10,000 credits in staging you will also be able to use it in the live site.
January 8, 2025 at 1:24 pm #16573633
alinaM-7
Yes please consolidate everything under one and let's see what happens. Thanks!
January 8, 2025 at 8:29 pm #16575248
Bobby
I have consolidated them and now you have a total of 35,966 credits.
Please try the following:
- make a small edit and update the page
- update the translation
Let me know your results
January 9, 2025 at 10:25 pm #16579979
alinaM-7
Good news! I am now able to make an edit in english, submit the page for translation and see the results. I can also edit the translation without getting the error message that someone else is editing the post.
One strange behavior I'm seeing i that when I go to edit the translation, when I hover over the eye icon, the tooltip says "Refreshing translation status" rather than showing me the pencil with the "Edit the Spanish translation" tooltip like the other pages. (see screenshot.) So the only way to edit the translation is to right click on the eye icon and then open the link in a new window.
I do still have the original issue from this thread: When I go to review or edit a translation, I often get a message to "Save all sentences before finishing", even if I have not made any changes. It's unclear which sentences need to be saved, so I may need to click 20 or more save buttons before I can save a tiny edit to one sentence. Is this an intended behavior?
I'm also still seeing this error message about formatting markers on some of the sentences (see screenshot). It's not clear whether this is related to the saving problem.
January 10, 2025 at 6:22 pm #16582890
Bobby
I'm glad to hear that this has helped!
#1
The eye icon shows when a translation is ready for review before it is published
Documentation: https://wpml.org/documentation/automatic-translation/how-to-review-automatic-translations-on-your-site/
Go to WPML->settings-> switch to 'publish right away without reviewing' to avoid going through this procedure.
#2
The HTML Markers will prevent a translation to be finished at 100% and saved.
One way to quickly resolve is by clicking on the "bolt" icon to automatically translate that section which also applies them correctly OR manually doing it
Docuemntaiton: https://wpml.org/documentation/translating-your-contents/advanced-translation-editor/#safe-html-editing
#3
When the status of a translation next to it shows a broken line such as in the screenshot, it signifies that these items are not fully saved.
A quick way of moving through them is ctrl + enter or cmd + enter but again HTML markers can cause this behavior as mentioned above.
The topic ‘[Closed] errors when using ATE’ is closed to new replies.
