- | 9:00 – 18:00 | 9:00 – 18:00 | 9:00 – 18:00 | 9:00 – 18:00 | 9:00 – 18:00 | - |
Related documentation:
Last updated by Waqas Bin Hasan 6 months ago.
Assisted by: Waqas Bin Hasan.
January 2, 2025 at 7:45 am | |
johannesv-2 |
January 2, 2025 at 8:05 am | |
January 2, 2025 at 12:34 pm #16558818 | |
Waqas Bin Hasan WPML Supporter since 05/2014
Thank you for your patience and cooperation. I am still working on this and 'll get back to you by tomorrow. |
January 3, 2025 at 7:20 am #16560380 | |
Thank you for your patience and cooperation. I'm trying to figure out the real issue here, although, when I remove that filter I can see the Orders page taking ages to load (with very high number of queries). But probably that's not totally on WPML or WCML. Since there are dozens of plugins, including custom plugins to support your custom theme, this is an expected scenario. Because, if I check with standard Beaver Builder theme, WooCommerce, WPML plugins and YITH WooCommerce Multi Vendor Premium plugin, it takes significantly less time and load. I'll request you try the following to determine when exactly the issue starts happening: Take a full backup of your site and database before proceeding. It is highly advised to try these on a dev or staging site first, so your live site isn't compromised. 1) Deactivate all plugins except WPML, String Translation, WooCommerce, WCML and YITH WooCommerce Multi Vendor Premium plugin. Please let me know your findings and I'll try my best to further help you on the matter. |
January 3, 2025 at 1:40 pm #16561543 | |
johannesv-2 |
Thank you for your feedback. It is of course to be expected that the large number of plugins would increase the number of DB queries. But the number only really skyrockets when YITH Multivendor and WCML are activated at the same time. Although I have already carried out various tests with standard themes and plugin deactivations earlier, I have run through the whole procedure again as desired. Findings Conclusion I assume that this illustrates once again that the problem arises in the interaction between YITH Multivendor and WCML. I would appreciate it if you could investigate the problem further. Many thanks in advance! |
January 6, 2025 at 7:19 am #16565156 | |
Thank you for the detailed information, I'm proceeding further along these lines and 'll discuss with my team as well. I'll get back to you accordingly. Thanks again for your patience and cooperation. |
January 7, 2025 at 6:04 am #16568000 | |
Thank you for your patience and cooperation. I've reported the matter for some advise and information to our 2nd tier team and I'll update you accordingly. However, in the meanwhile I may need to take a backup of your site by using Duplicator or All-in-one-migration plugin. This may be needed for our 2nd tier team to investigate the issue locally and/or in another environment. I just wanted to ask if this is OK for you? If you'd like, you can remove any sensitive data from the site prior to allowing for the above mentioned. Please let me know. |
January 8, 2025 at 6:44 am #16572156 | |
johannesv-2 |
Thank you very much for the feedback. You are welcome to take a backup of the page if required. I look forward to hearing from you again. |
January 8, 2025 at 12:26 pm #16573220 | |
Thank you for the permission, I'll create a package soon and 'll escalate accordingly. In the meanwhile, I've installed WCML 5.4 beta 1 and did some tests (as recommended by the team). Can you please take a look and check as per your tests and see if that helps improving the situation? |
January 9, 2025 at 1:08 pm #16577901 | |
johannesv-2 |
Thank you very much for your feedback. Unfortunately, WCML 5.4 beta 1 does not seem to provide a solution either. Here are the results with a standard theme activated and only the most necessary plugins (including YITH) activated: |
January 10, 2025 at 6:34 am #16580353 | |
Thank you for the updates, I've taken a backup of your site and have forwarded to our 2nd tier team for further investigation. I'll update you accordingly. Please note that it may take some time (due to the weekend as well), but we'll try our best to get back to you as soon as possible. We appreciate your patience and cooperation. |
February 4, 2025 at 1:10 pm #16666793 | |
johannesv-2 |
Hi there, I've just wanted to ask, if there's any update on this as a few weeks have passed since your last reply? Many thanks in advance. |
February 6, 2025 at 6:34 am #16673630 | |
Thank you for your patience and cooperation. The issue has further been escalated to our dev team some time ago and they are working on it. However, in the meanwhile they've published this errata at https://wpml.org/errata/high-query-load-on-woocommerce-orders-page-when-using-multivendor-plugins/ with a temporary solution. I recommend trying that workaround and subscribing to the comments of the errata for any future updates. Unfortunately there's no ETA so far. |
