Unable to add glossary with hidden languages
Under your site Dashboard, go to Users > Profile, Or you can go to Users > All users, Select a User to edit there you can set the "Display hidden languages" and save.
Last updated by the-one-real-estate-d.o.o.T 2 years, 8 months ago.
Assisted by: Raja Mohammed.
February 24, 2022 at 10:57 am
I tried adding the word to the glossary as you suggested but it's only giving me the option of two languages even though I have 5 on my site?
February 24, 2022 at 11:54 am
February 24, 2022 at 11:57 am #10655269
Raja Mohammed
Hello there,
Can you please try updating WPML to the latest version 4.5.5, Let me know once done.
You can update from Plugins > Add New > Commercial, click on Check for updates, Select the installed WPML plugins, and hit Download with Activate option selected
Regards
Raja
February 24, 2022 at 1:23 pm #10656091
Hi, I updated but it's still not showing all the languages
February 24, 2022 at 6:25 pm #10658595
Also, upon following your instructions for the strings:
1) Goto WPML > String translation,
2) Scroll down to the section Auto register Strings for translation section and enable the option
Look for strings while pages are rendered option
3) Once done Open the page in Frontend where the string appears, Refresh the page a several times
4) The string should now appear in WPML > String translation
5) Disable the option enabled in step 2
my site seems to be performing very slow. Is this connected with this?
February 25, 2022 at 1:27 pm #10664213
Raja Mohammed
The slowness is temporary it should recover well after a while.
Regarding the Glossary, I have noticed the hidden languages are not displayed in the Glossary section. As a workaround, Temporarily unhide the languages after which you should be able to add the Glossary terms for all the languages. I will report the same to the concerned team so that our developers can take care of the issue.
February 28, 2022 at 10:38 am #10675995
Raja Mohammed
We have an update regarding the Glossary terms, Since the Languages are hidden, Please go to the User profile and set the "Display hidden languages" option. That should display the hidden languages in the Glossary terms.
February 28, 2022 at 10:45 am #10676099
Hi, thank you! Where is User profile located?
February 28, 2022 at 12:11 pm #10676679
Raja Mohammed
